Old 04-18-2024, 06:44 PM   #1
Too much rust?
I wanted to get everyones opinion on this bus. Has a great engine and transmission but is this considered too much rust on the bottom? From the inside, its been stripped, sanded, welded and 2 coats of the rust metal paint.
Thanks!
437215266_2149221922113773_5594305263130250316_n.jpg   437284360_1307975557271431_1670050293552886728_n.jpg   437284362_965556988297193_3162252753639941309_n.jpg   437516710_446189184596115_1203347079487827955_n.jpg   437784265_963316938691134_6991279049310742434_n.jpg
Seadragon is offline   Reply With Quote
Old 04-18-2024, 06:54 PM   #2
ewo1's Avatar
It's not real bad, with some corrective action it will last quite a long time.
Easiest corrective action, wire brush, OSPHO and rattle can paint.
next would be some light sandblasting, OSHPO, paint.
Where you got rust holes, cut out rust, clean, OSPHO, weld in new pieces and paint.
Many of us here have tackled worse, including me.
What engine tranny combo you got?
Old 04-18-2024, 11:41 PM   #3
Thanks for the tips. It's a 2004 CE International CE300 with a DT466 and an Allison 2000. Still shopping around for a bus and had the owner send me these pics.
Old 04-24-2024, 11:00 AM   #4
nikitis's Avatar
Rated Cap: 29
I agree with EWO1. I've seen worse. The chassis rails are thick metal so even some rust on them is fine. The last pic with the underfloor rust will be the biggest concern as it's thinner. Make sure you can't poke a flat heat screw driver through any of it, and if not it's workable, and if it's only a small area that pokes through still workable, just will require some welding to fix.
Old 04-24-2024, 01:57 PM   #5
Chassis: International 1753
Engine: 6.9 International
Looks fine to me. Someone from the desert southwest is likely hyperventilating at those pics. Is that in eastern ohio? I think I recognize the dealer on the mudflaps.
