Old 09-13-2021, 09:07 AM   #1
T-Bolt's Avatar
Engine: DT530
Tow Capacity
Does anyone know the tow capacity of my bus?
International RE DT530
I was thinking about bringing a couple of sons down south to help cleanup from Irma. Saddly my oldest that can drive has flown the coup so I would want to haul my truck down on a flatbed trailer. I'd be bringing an F250 weighing 6500 empty plus the trailer.
https://eternitybus.com
T-Bolt is offline   Reply With Quote
Old 09-13-2021, 11:34 AM   #2
84 -150lb passengers weigh 12600lbs. Pulling 7500 should be no sweat.
Old 09-13-2021, 01:26 PM   #3
JacquesM's Avatar
Year: 2013
Chassis: F292151 - 36ft Flatnose
Engine: Cummins 5.7L
Rated Cap: 16425 KG
I used to pull a 10,000 lbs generator with my 9.0L International.
No problem, but I had a good welder fabricate the HD hitch system.
JacquesM is offline   Reply With Quote
Old 09-13-2021, 02:47 PM   #4
Chassis: IH 3800
The weight wont be a problem. Just make sure the hitch setup you run is up to the task.
