Those first two shots at the suspension. Actually somewhat of a good thing. Notice that little bump on the vertical piece? That is called a grease zirk, if you don't know what that is, I suggest you find out and squirt grease into it at defined interval. That is what the previous owner did to it, and that is what you see oozing out of the seals, which then collected dirt etc....
