Old 09-10-2024, 04:17 PM   #1
Water tank vent
Do you need a vent for your drinking water tank? If so, recomendations?
KrazyKarl is offline   Reply With Quote
Old 09-10-2024, 07:19 PM   #2
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
Yes. Make the vent with a filter at the end and make the end a couple feet higher the the top of the tank to prevent spillage.
flattracker is offline   Reply With Quote
Old 09-10-2024, 07:21 PM   #3
fo4imtippin's Avatar
Chassis: TC2000 28ft
Yes. It doesn't have a stink to it, so you can vent through the floor. I have a 1.5in hose going into the top of the tank and then I have another 1.5in hose next to it going down through the floor. This also means if I overfill the tank it will come out through the vent. If you have zero vent, and you have a non vented cap on your fill hose, then your water pump could vacuum your tank collapsed.
Old 09-10-2024, 07:37 PM   #4
Coachwork: Busless for now
I'm with flattracker on the vent. My sticks & staples truck camper has a 1-1/2" gravity fill hose and a 1/2" vent/overflow hose going into the side of the tank right at the top. They exit though the side wall a foot or so above the top of the tank. The vent is right next to the fill.
I would be afraid of siphoning my tank empty with a bottom exit if you tilted a good bit the right direction with a full tank.
Just a thought.
Kentucky Dreaming is offline   Reply With Quote
Old 09-10-2024, 08:27 PM   #5
Thx all!!!
Old 09-10-2024, 09:29 PM   #6
The purpose of a filter at the end of the vent is to protect the fresh water from things like bugs and other contaminates.
Old 09-18-2024, 08:56 PM   #7
Bluthebus00's Avatar
Chassis: C1FE 2509
Engine: Cummins ISB 5.9L 24V ~ AT545
Rated Cap: Seats 5. Sleeps 4
Everyone's already answered yes but I figured I'd drop in and share what I did. I purchased this fixture for my rig. It gives me gravity feed to fill my tank, a city water hookup, and in the center hole is the vent tube for the fresh water tank and for overflow when filling the tank.
Mfg: Valterra
Model# A01-2000VP
It was about $40 for me 5 years ago.
Bluthebus00 is offline   Reply With Quote
Old 09-19-2024, 07:59 AM   #8
Count me voting for a filter as well. I’d use a water filter so if the filter got wet it would not fall apart
Mekanic is offline   Reply With Quote
Old 09-19-2024, 12:12 PM   #9
Coachwork: IC
Chassis: RE300 FLAT NOSE
Engine: 2006 DT466 HT, 260 HP
Rated Cap: 81
Vent
If you are installing a gravity fill inlet for your bus they can come with a vent hookup built in. You just need to run the vent line from the tank. If you are installing a hose pressure connection inlet you will need to run a vent line to the outside of the bus. Vent from the top of the tank and make sure the vent end connection to the outside is higher than the tank connection.
More2See is offline   Reply With Quote
Old 09-20-2024, 11:20 AM   #10
Chassis: Ford E450
Engine: V10 Gas
Mfg: Valterra
Model# A01-2000VP
I installed the exact item. It is a piece of crap. Not UV safe (already yellowing after two years). There are better products. Return it or toss it, and use one of the better versions.
