05-28-2020, 05:09 PM
Chassis: MVP
Weight
I have a 1992 Thomas Sat-T-Liner with the 5.9 Cummins. All of the seats have been removed.
Anyone have an idea what this thing weighs? Just curious.
Thanks.
05-28-2020, 05:16 PM
How many windows?
05-28-2020, 05:26 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
my bus
24 feet no seats cummins 5.9 manual transmission 10,000 lbs estimated
same bus, no engine, transmission or anything at all related to an engine no seats, a bare, steering, braking, rolling shell 6,200 lbs
william
05-28-2020, 05:31 PM
Chassis: MVP
If I remember correctly, it has 11 windows per side. It is approximately 35 ft long.
05-28-2020, 05:41 PM
Thanks.
IF its a 40 footer around 17-19k.
05-28-2020, 05:42 PM
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Likely ECCB is very close. But the only way to know for sure is to find a truck stop and pay the usual $15.00 for a truck scale. Small price to pay to know for sure, and you will get actual weight per axle and total weight combined.
These scales are set up with independent concrete pads on heavy springs and pressure plates to measure weight. Pull on them slowly, and brake gently to avoid damaging the scale.
Be sure that your two axles are on different pads, and not on the seam between pads. There will be a call box to request a weigh. When they weigh it, they will tell you to come in and get your ticket. Pull off the scale and find a safe place to park, it is NOT kosher to park on the scale or to block the scale.
"CHEESE WAGON" <anomaly.va@gmail.com> Suggested reading: (4 threads)
05-28-2020, 05:55 PM
Mine is also 11 windows and 35 ft long. Weight was 16,250 lbs. with all seats and floors removed.
05-28-2020, 07:12 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
Alternatively if you don't need an official weight but just an approximate, many Ag plants have scales in the vicinity of the silos which have a digital display you can read from the driver's seat. If you want front and rear axle weights, pull half on, stop, note the weight as front axle only, pull all the way on, stop, note the weight as full vehicle, subtract first from second numbers for rear axle weight only.
05-28-2020, 07:19 PM
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
This is indeed true, but I've seen these scales off by a LOT before. A paper mill I hauled out of was off by about 7,000 lbs on the drive axles because it was a platform scale we had to use this method with, which doesn't always work for a five-axle trailer truck.
What throws things off is that there is usually an incline to the scale platform, which has the vehicle pointing uphill when weighing only the front axle, and pointing downhill when weighing only the rear axle. And sometimes that can throw things WAY off. As you said, approximate, but sometimes it's not even close.
I actually got in a shouting match with several people at a produce shipper because they insisted their scale was certified and I knew there was no way it was right, nor was it certified.
They backed down when I told them to show me the paperwork certifying it, because there was no way my 53-foot reefer fully loaded with crates of apples was only 37,000 lbs (which would put the truck about 72,000 gross). The CAT scale 30 miles away said 81,050. Guess I won that round. ;)
Not in regards to you, Sehnsucht, just in reference to the idiots at that shipper that thought they knew everything. LOL
05-28-2020, 07:31 PM
Chassis: Ford F53
I know what you mean about idiotic shippers. Only overweight fine I ever got I didn't even scale it, my co-driver did at pickup and they only gave him the full weight so he took them at their word it was legal. 6 paper rolls, loaded from the nose, drive axles over by more than 2k! I knew something was wrong as soon as I started driving because it was very heavy on the drives. Then the weigh station was opened....
My expectation is that even if it's not totally accurate it'll at least give the OP a reasonable idea and save $15
05-28-2020, 08:26 PM
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
Gravel pits have scales too. The ones in our area charge $8-$10. Just don't catch them on the day after a big rain storm....  Cheese is right, there is a procedure and etiquette involved in using one.
Dave
05-28-2020, 09:36 PM
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
I got that one beat. Idiot dispatcher set me up with a dry-van load of 26 liquid totes (I don't have the T endorsement, mind you).
For the uninformed, commercial liquid freight requires a T (tank) endorsement if over 119 gallons. This was way more than that. I was pretty sure I wasn't supposed to haul that load, but they claimed dry van loads did not require it.
Ground loaded, improperly, and somewhere along the line the totes slid forward, loosening the strap so it could later slide back to the trailer doors. Got popped for 7,100 over on the tandems. Slid what I could to state law and it was still 5,800 over. Cop wrote the ticket for 5,800 over to the company, not me, thankfully. Apparently they had gotten known for running overweight out of a local creamery. I think what saved me was I had a scale ticket showing it was legal when I was loaded.
But I digress. Sorry to the OP for hijacking the thread.
