Old 11-15-2020, 10:05 AM   #21
Chassis: chevy
Engine: 3116 catapillar
Originally Posted by BusWanderer83 View Post
Do you have a pic? Mine looked like a heat register but the ceiling panel was all one piece...just curious
Its for venting the moisture of of the insulation i believe. Ill be using a dehumidifier so i removed it and sealed the hole. I had a rain issue if it was parked wrong . The rain was getting inside and dripping on the dash
mmoore6856 is offline   Reply With Quote
Old 11-15-2020, 10:19 AM   #22
Chassis: Vista 3600
Rated Cap: 24000 lbs
We used this location to mount our rooftop air con unit
RolesvilleMarina is offline   Reply With Quote
Old 11-15-2020, 02:56 PM   #23
You need a place to get some fresh air and oxygen depleted in the cabin.
Lemorlove is offline   Reply With Quote
Old 11-16-2020, 08:10 AM   #24
Coachwork: Lance and friends
I removed mine and installed a Max air fan
Lwt52168@gmail.com is offline   Reply With Quote
