Old 11-21-2022, 05:02 PM   #1
Year: 2008
Chassis: International 40' FE FN
Engine: dt466E
welding / not welding floor pans
i have a spot on the floor that needs to be cut out and replaced. do i have to have the new pan welded in. could i overlap the new metal patch, add adhesive between layer and screw down.
also, what guage is the floor or floor gauge should i use.
Fahntastic Life is offline   Reply With Quote
Old 11-21-2022, 05:12 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
please fill out your profile so we know what bus you are asking questions about.
they dont have to be welded.
your choice?
they can be primed and lapped with sealant if you need.
Old 11-21-2022, 06:09 PM   #3
That would work fine. You don't have to weld anything like this.
Your floor is probably 16 gauge, but your patch can be whatever material you happen to have handy.
Old 11-22-2022, 01:53 PM   #4
Year: 2005
Coachwork: Bluebird All American
Engine: Cat C7 ACERT
Rated Cap: 54
I have two holes in my floor that needed patches, both from heater removal. I just cut a patch from some thin steel and screwed them into place. I did this knowing that I would be putting insulation and plywood over the floor in the near future.
doncobb is offline   Reply With Quote
Old 11-23-2022, 11:44 AM   #5
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Rather than screwing patch plates down I'd suggest using blind rivets.
Cut the patch larger than the hole by an inch or inch and a half on all edges.
Hold the patch in place and drill the appropriate size and number of rivet holes. CLECO's work great to hold it in place after the first and second holes are drilled.
Apply polyurethane sealant like Locktite PL-3, and install the rivets. You can use a hand, air, or cordless electric riveter. I recommend the air rivit gun sold by Harbor Freight though if your budget allows there are better (and more expensive) rivit guns out there. Also, go with zinc coated steel blind rivits NOT STAINLESS as your floor is galvanized (your patch should be as well) and I've been told that stainless doesn't play well with galvanized.
In fact, any time you have dissimilar metals (even different alloys with the same base metal) you will have galvanic corrosion. The closer the two are to the same material, the less galvanic action there will be.
HamSkoolie is offline   Reply With Quote
