What do you think about this bus?
Here's a bus I see for auction not far from where I live, wanted your opinion on its specs.
2004 Thomas Saf-T-Liner MVP EF (whatever that means - is the "MVP" model a higher-level model of Saf-T-Liner?)
72,877 miles, Cummins 5.9 "EFISB205" engine, Allison AD2000 transmission (appears to be at least 5 speeds with lockup and overdrive from what I can tell, rated for up to 30,000 pounds, but is it a GOOD transmission?)
78" interior height, full length, front engine with flat nose, air brakes, appears to have underbody storage. The listing claims that it "started right up". Appears to have a small amount of superficial rust near the front wheel well and on the silver trim covering the front edge of each of the steps. Spent its entire life in northeast Ohio.
What are the thoughts of those of y'all who know much more than I do? Any suggestions on a good price for this bus? (The auction ends in two days. For me, I don't know if it's ideal, if for no other reason than because it's full size. I had been thinking that a mid-size bus would be better... but I suppose full size has its advantages...)
