09-24-2019, 06:39 PM
#21
Chassis: 1997 bluebird AAFE cummings 8.3
man some of these posts are really hard to understand on this thread. People are now slapping at the keyboard like its a text message and i'm over here like where's the complete thought?
09-24-2019, 06:47 PM
#22
18ga. lol
09-24-2019, 07:35 PM
#23
Engine: 6-71TA
Rated Cap: 90
The lowest I would go is 16ga and that is already difficult to work with.
09-24-2019, 07:56 PM
#24
If the span is around 2', 20 guage works just fine, that's what I used, doesn't oilcan or anything and is cheaper than 18g
09-24-2019, 08:27 PM
#25
Originally Posted by Genghis
There was tubular steel framing the seats, but there was sheet metal on the backs under the Upholstery between the framing. The sheet metal was the size of the seat backs, ~ 3' x 2'. I recovered about 30 + pieces from my 77 pax Thomas.
Genghis sends.
z
It's all bent though, isn't it - for stiffening? Or were your backs completely flat?
09-24-2019, 08:28 PM
#26
FWIW my $30 Harbor Freight shears can easily cut at least down to 14ga (I haven't tried thicker).
09-24-2019, 09:23 PM
#27
Skinning in 16 or 14 is just a waste and way more work than its worth. Takes way more to cut and drill that thick plate.
09-25-2019, 03:57 AM
#28
Is that the one labled to handle 20 gauge? I saw it many times and thought it would be too light.
09-25-2019, 05:21 AM
#29
No, I think that's the swivel-headed one. The normal shears advertise 14ga and actually work fine for that thickness.
09-25-2019, 11:05 PM
#30
Thank you.
09-30-2019, 09:22 AM
#31
Coachwork: Tomas
Engine: 7.3l
Find a end roll
I used a end roll of 18 Guage I got for couple hundred Canadian dollars.
10-02-2019, 01:25 PM
#32
Chassis: MVP ER
18 gauge galvanized, they were cut already had to remove only a couple of inches 3x10 ft. Would not go heavier, cut ok with the cheap HF electric shears. The red and green aviation sheers cut through them well.
10-02-2019, 01:26 PM
#33
Yeah imagine trying to work with anything thicker!
04-20-2021, 09:35 PM
#34
I was reading this thread and noticed no one is using aluminum.
May I ask why?
04-20-2021, 10:19 PM
#35
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
May I ask why?
Galvanic corrosion (also called bimetallic corrosion or dissimilar metal corrosion) is an electrochemical process in which one metal corrodes preferentially when it is in electrical contact with another, in the presence of an electrolyte. A similar galvanic reaction is exploited in primary cells to generate a useful electrical voltage to power portable devices.
-wiki
04-21-2021, 05:54 AM
#36
May I ask why?
Check out the cost of aluminum sheet. Probably cheaper to use hardened unicorn's tears.
04-21-2021, 09:52 AM
#37
If you are thinking aluminum for something that doesn't rust or rot, there is fiberglass, it adheres to steel and diy its cheap.
Given the floor is going to be covered with foam and thick wood, I don't see the need for the steel at all.
02-17-2022, 03:26 PM
#38
Have a question
Hey where did you get a price that good for steel sheets that were 18guage to 20 guage for that size? I am getting quotes for triple that so thought I may see where you got your quote from or by now you may have actually purchased it. My email is dealsforyou2015@yahoo.com please lmk thanks so much for your time!
Lindsey Wagner
QUOTE=Twigg;262454]What gauge of sheet steel are folk using to skin-over windows?
I was planning to use 18-gauge, but I noticed that dzlfreak used 20-gauge and he had more distance to span than I have.
I have quotes of $75 for a 8 x 4 sheet of 1008 at 18-gauge and am assuming the 20-gauge will be about $60, and a lot easier to cut and handle.[/QUOTE]
02-17-2022, 05:39 PM
#39
Rated Cap: 31,800 pounds
Lindsey Wagner
[/QUOTE]
The post with those prices is four years old. Someone resurected an ancient thread.
02-17-2022, 08:09 PM
#40
Engine: 3208 na boat anchor
I used FRP (fiberglass reinforced plastic) for blanking my windows. It's the stuff they build RV and semitrailer siding with. Bought a big old roll of the stuff, and have used it for many other things. I blanked windows individually.
