Old 05-28-2020, 10:03 AM   #1
witchywoman's Avatar
Year: 2006
Rated Cap: 30
What is this thing???
One seat is attached only by this. Does anyone know what it is and how to get it off????
266D0FDB-9EE3-442F-A599-A9B5E1C63D85.jpg   2F65E069-753D-46E6-90C5-1772F58B29B6.jpg
witchywoman is offline   Reply With Quote
Old 05-28-2020, 10:13 AM   #2
Year: 2006
Chassis: Safe-t-liner ef
Rated Cap: 54 passenger
that looks to be a Rev. Nut. Does it spin while you are trying to unbolt the seat?
You can try to hold it with channel locks and replace it with a nut later.
Nbigger is offline   Reply With Quote
Old 05-28-2020, 10:14 AM   #3
Looks like a hole was drilled too big or stripped. Thatís an anchor. Iíve never seen one like that. Canít you unscrew the bolt? Thereís always angle grinders
Old 05-28-2020, 10:39 AM   #4
Year: 2006
Rated Cap: 30
My angle grinder won’t fit in there. It’s sitting in a weird spot. I tried holding it in place and using a ratchet on the top but nothing budges.even with WD40 to try and loosen it. Literally the only thing holding the seat in. I’ll just have to keep trying. Thanks.
Old 05-28-2020, 02:27 PM   #5
Year: 2006
Vise grips could work or if you can wedge something on the metal gripers that would keep it from spinning. Those go into a hole and when you tighten the bolt it pulls the metal and grips onto the hole it is in. Looks like the anchor did not grip good enough and it is spinning. A orbital cutting tool might work in that area but thats my only other idea.
Old 05-28-2020, 02:34 PM   #6
Year: 2006
Rated Cap: 30
Thanks. I’ll try anything at this point.
Old 05-28-2020, 02:49 PM   #7
ewo1's Avatar
Originally Posted by witchywoman View Post
Thanks. Iíll try anything at this point.
I would give an air chisel a try.
maybe you can cutoff those bent back tabs and be able to slide out the barrel/bolt !
Old 05-28-2020, 04:59 PM   #8
Looks like just a bolt head and washer on the top of this. They make long extensions for socket wrenches, which should let you access the bolt head (that's how they got it in in the first place, most likely). That thing is a threaded insert welded in place, so you don't need to worry about holding it with a wrench at the same time.
musigenesis is online now   Reply With Quote
