Originally Posted by Armonius
Okay that makes sense. What does coolant in the oil indicate? Or as you said oil in the radiator cap area? I think those would mean big issues inside in the engine where areas are leaking right...
Also how do I tell what engine that is?
Coolant in the oil OR oil in the coolant - bad signs...walk away...unless they give it you for free!
A real good reason aside from what was said, to check the engine cold, lets you pull the dipstick to see the oil before it gets mixed up. It's always a great idea to check the oil BEFORE you start an engine for obvious low level reasons but also to check for coolant in the oil pan.
how to tell what engine it is...many times there will be a label on the motor but the best thing to do is google engine types, study the pictures. every motor is different and has tell tale signs of what it can be.
also, with the VIN number, you can contact a dealer and they will give you specifics on the motor or a "Build Sheet"/"line set" on the bus and the parts used to build it.
