Old 04-01-2023, 01:56 PM   #1
Wheel replacement suggestions for this 1973 Chevy C65
I believe it says RA443 on the rim, I'm looking for a modern 19.5-22.5 replacement.
Serp is offline   Reply With Quote
Old 04-01-2023, 03:20 PM   #2
Coachwork: Collins
Chassis: NB18FD Oshkosh
Rated Cap: 18,500
No replacement for those. You need to replace hubs and rims from later model chassis.
PhilipE is offline   Reply With Quote
Old 04-01-2023, 03:24 PM   #3
What later model would I need to get parts from ?
Found this, seems expensive and I would need them for 3 axles.
http://www.hainsworthfarms.com/store...sion_Kits.html
https://www.southwestwheel.com/c-20-...-aluminum.aspx
Old 04-02-2023, 06:57 AM   #4
those are a standard dayton hub you sure can replace just the rim.. my bus has 22.5 x 7.5 rims on its dayton hubs.. I run 11R22.5 tires. 7.5" is generally the minimum for an 11R22.5 tire.. suggested for 10R22.5 as well.
here is an example of a new one
https://www.raneystruckparts.com/22-...MaAuSiEALw_wcB
but my advice would be to check with local salvage yards for a good set of used ones.. they were used on everything from school busses to many trailers.. if the original tire size was a 9.0 x 20 then a 10R22.5 is a close match in width and height.. they are a little harder to find.. if you have decent clearance up front and in the rear wheel wells you very well may be able to get a set of 11R22.5's on which are an easily obtainable standard modern truck tire...
as far as a year and model thats tough as dayton spokes were optiomns on many different years.. there are school busses as new as 98-99 with dayton spoke (maybe newer) and ive seen busses from the 70s with stud or hub pilot disc rims...
