Old 01-17-2020, 01:28 PM   #1
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
wheelchair track and hardware?
Hi
Ive been de-flooring and have removed some wheelchair(i assume) hold-down connectors. I intent to use them (for attaching or holding down heavy stuff temporarily) on my build if i can figure out how they work and get the requisite parts/straps.
here is a pic of a floor connector and soome wall track.
how does this stuff work, can i get mating parts and straps?
does anyone have a pic of a wheelchair or anything else secured using these?
thanks
evan
stlthe is offline   Reply With Quote
Old 01-17-2020, 02:28 PM   #2
farok's Avatar
Engine: 6.0L Gasser
Do a search in Amazon or YouTube for L Track accessories and you'll find all sorts of things. They are plenty strong and have all sorts of attachment options from studs to rings, etc. The attachment points aren't expensive, but the L Track itself is!
Chris
My build thread: https://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 01-17-2020, 02:30 PM   #3
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
https://midwestbusparts.com/index.ph...x&cPath=19_298
Old 01-17-2020, 05:50 PM   #4
stlthe's Avatar
Engine: Cat C7
Thanks guys. so "L" track is what it is... I'll be good to go from here, i just had no idea what it was called. i can say in my case it was easily removed, not to rub it in
Old 01-17-2020, 06:11 PM   #5
farok's Avatar
Engine: 6.0L Gasser
I'm glad this wasn't posted when I was in the middle of removing mine!
Glad yours came out easily, really!
Chris
