Originally Posted by RoamingQuebecois
Hello !
We bought a partially converted 2006 International BlueBird, which unfortunately doesn't have a driver seat. The previous owner threw it out and put a sofa there instead :/
We're trying to find a good price on an Air Ride seat, ideally not to buy it new. We are currently in Bend. Anyone has any recommendations as to how to find that? We called the local car junkyard, with no success. Any help is appreciated.
Thanks !
no idea what/where "bend" is...
Im in ohio and there are heavy truck / school bus junkyards all over that sell used air seats out of busses.. im guessing "bend" or nearby has something similar..
the mount plates are somewhat different for each bus brand but most can be made to fit.. make sure you have access under the bus to the driver area floor..
if you dont already have an air line run, you'll need to get a protector valve and install the 1/4" air line onto the Accessory air tank.. (dont just tap in anywhere)... the protection valve is important so your bus could still be driven if you popped the bellows in the air seat or the line blew... dont skip that part..
