Old 02-14-2021, 10:27 AM   #1
Chassis: All-American flat face
Which diesel fuel cap?
My diesel fuel cap was stolen. Do I replace it with a vented cap? Non-vented?
I have a 2001 bluebird TC FE 2905.
Thanks
CorbettO is offline   Reply With Quote
Old 02-14-2021, 11:26 AM   #2
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
My tank has vent port and the cap is not vented. Maybe look into a lockable cap. I'll be putting one on when my bus is ready to hit the road.
Ted
Old 02-14-2021, 11:33 AM   #3
Rivetboy's Avatar
My 91 BB 5.9 also has a vent in the tank and a non vented Locking fuel cap behind a locked fuel door.
Rivetboy is offline   Reply With Quote
Old 02-14-2021, 01:07 PM   #4
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
I just have a screw on brass cap behind a locking door
98 TC 2000
Rwnielsen is offline   Reply With Quote
Old 02-14-2021, 01:28 PM   #5
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
My cap is not vented, and the lock will jam if I lock it, and I have to turn the key with a pair of pliers. Seems to be the corrosion starting on the inside of the tank; the lock turns freely when the cap is not installed.
Old 02-14-2021, 07:05 PM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
For our buses, the fill port and cap location is behind a locking door flap. But on our Freightliner ambulance, the fuel cap is exposed on the tank beneath the steps. We had to replace the cap with a locking one, to meet some convention show requirements in Austin, and we paid about $100 for a nice Stant locking cap. And even though it's a top-quality cap, it's a bit scary to use. The locking mechanism is a toothed cam and if you lock it, then someone (intentionally or accidentally) tries to unscrew the cap...or if they fire marshal tightens to make sure it's secure, the teeth grab the inside of the fill pipe and it's then very hard to unlock. Although I've not yet broken the key, it sure makes me cringe. If it weren't for the show requirements at some events, I'd skip the locking cap.
On a side note, a regular 2" threaded pipe cap works fine. But most "real" caps have meltable sections, in case of a fire I guess...
cap, diesel, fuel
