Old 03-16-2021, 09:10 PM   #1
Windows
Is anyone aware of any aftermarket windows that fit and look original but are higher quality with better insulating capabilities? Seems a waste to spray foam everything but leave all the stock windows. If not, how difficult is it to remove, sheet metal and add RV windows on a scale to not that bad to nightmare?
KoehlerFarms is offline   Reply With Quote
Old 03-16-2021, 10:11 PM   #2
Bus windows are single-paned, so their insulating value is R-fuhgeddaboudit. Even double-paned RV windows aren't fantastic insulators, and even their hermetic seals will eventually fail from the road vibration. I've kept all my original bus windows in place and I'm building covering inserts for them out of 2" XPS foam board faced with 5mm plywood, held in place with snap-down draw latches, easily removable as needed. For fun I'm even going to trying building a few of these with double-paned glass salvaged from house windows embedded in them, to get at least a little light in side when I'm buttoned up in XPS.
Doing a DIY window swap in a bus is maybe a 2 on your scale, definitely doable and something from which you will develop skills that will be useful elsewhere on your project.
Old 03-16-2021, 10:59 PM   #3
Engine: 6-71TA
Rated Cap: 90
Peninsula Glass Company makes custom windows but they are pricey. I am also looking for windows but prefer the parallelogram style.
GWRider is offline   Reply With Quote
Old 03-23-2021, 08:39 PM   #4
Lee Savoy's Avatar
Chassis: FE300
Rated Cap: 53
I stumbled across the fact that Lippert offers bus replacement windows a night or two ago. I emailed them asking about our bus and OEM replacements, but haven't heard back.
https://www.lci1.com/school-bus-windows
We're waffling back and forth between our stock windows and skinning with RV windows. I don't know..... Right now we're back to stock with covers something like musigenesis is talking about doing.
Harvey The Bus build thread
Lee Savoy is offline   Reply With Quote
Old 03-23-2021, 10:02 PM   #5
I've made two of them lol. It's not just talk! Darned warm weather killed my motivation to finish them.
Old 03-25-2021, 06:59 PM   #6
It's as easy as removing all the windows, welding sheet metal to replace them. Then weld steel tubing to frame where your RV windows will go. Cut the holes out and sandwich in the windows.
[/URL]
Old 07-26-2021, 09:15 AM   #7
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
[/URL]
Do you have a build thread, a post, or more pictures that show this process? This is what I am envisioning doing. Did you have a source for the windows that was reasonable priced?
Thanks!
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Old 07-26-2021, 11:59 AM   #8
Thanks!
Build thread is called The Bucket List. I shopped for windows on ebay from RV suppliers and used distributors.
https://www.skoolie.net/forums/f11/t...-22665-40.html
windows insulation
