Old 07-13-2019, 11:48 AM   #1
Wood on outside of Bus
So I recently got my first bus and was thinking about muting some cedar to the outside (or something like it) and I have only found 2 photos of people who have done this to the exterior of their buses. So figured I would come here and ask if anyone has an idea how to do it, or done it before.
Photo for example only
FarmhouseMetals is offline   Reply With Quote
Old 07-13-2019, 12:06 PM   #2
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
For Esthetics only or as insulation or to get that Woody look?
Sehnsucht is offline   Reply With Quote
Old 07-13-2019, 12:08 PM   #3
Wood is about R1 per inch, so I'm assuming aesthetics.
Old 07-13-2019, 12:10 PM   #4
Coachwork: Blueburd
Chassis: International S1800
Engine: 9.0L International Diesel NA
My worry would be that it would hold moisture against the sheet metal and invite rust. You could seal the wood in epoxy or a **** ton of lacquer. A vinyl applique might be a better solution if going for the "woody" aesthetic.
Rochey6957 is offline   Reply With Quote
Old 07-13-2019, 12:16 PM   #5
Just for looks. I own a metal sign business called Farmhouse Metals, and this is going to be my mobile store. So the touch of rustic on the outside is an idea I would love to add, but curious about making it stay to the outside.
Old 07-13-2019, 12:17 PM   #6
Very true, I have no problem getting treated wood, staining it color I want, and sealing the heck out of it. It's good food for thought before just running off and drilling it there
Old 07-13-2019, 12:39 PM   #7
Coachwork: 1991 bluebird
A metal sign business. I would think more along the lines of something like this. They also have an activator to age it. Should be listed with it.
https://www.amazon.com/dp/B000Z4DSVO...v_ov_lig_dp_it
jimburke77502 is offline   Reply With Quote
Old 07-13-2019, 12:48 PM   #8
Yes I know lol I mount designs on wood, plus the marketing name of Farmhouse, want to do a certain look. Plus, it would just stand out. I DID think of doing the copper metal look too
Old 07-13-2019, 12:48 PM   #9
Chassis: Ford F53
Precisely and this is why I asked. I have a project idea in mind called Project Griswold which is a green bus with 80s faux woodgrain paneling but I've determined that a vinyl applique is the easiest way to achieve the desired appearance without inviting other issues.
Old 07-13-2019, 01:03 PM   #10
Wagon Queen Family Truckster
Old 07-13-2019, 01:21 PM   #11
Chassis: Ford F53
Yup, that's Project Griswold!
Old 07-13-2019, 01:50 PM   #12
I would LOVE a family truckster!
Old 07-13-2019, 02:29 PM   #13
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Rochey beat me to it... Would definitely hold moisture against the body and cause rust / rot. One thing that might help with this is to coat the areas in question with Kool-Seal before mounting the cedar, and use corrosion-resistant screws. If you can keep rust and rot at bay, I think it would be a pretty cool look. Definitely unique.
Old 07-13-2019, 04:04 PM   #14
Knife makers use a polymer product to stabilize wood used to make handles. It’s done in a vacuum to assure complete saturation. But in this instance maybe encapsulation is adequate. After it’s completely sealed then it could be glued and screwed to the surface of the bus.
Old 07-13-2019, 04:34 PM   #15
I'd be inclined to use a wrap, just cuz it's easy and unlimited design possibilities.
https://scontent-lga3-1.cdninstagram...ninstagram.com
"Reality is that which, when you stop believing in it, doesn't go away" - Phillip K. Dick
JustKip is offline   Reply With Quote
Old 07-13-2019, 04:40 PM   #16
Use standoffs (nuts and washers) to hold the wood away from the surface.
Old 07-13-2019, 06:32 PM   #17
plfking's Avatar
Rated Cap: 34
I've used about 6 coats of spar varnish or spar urethane on all sides of untreated wood, with no issues (approx. 1 year on the bus, 5 years on the truck). I attached the single boards with self-tappers....on the truck, I bolted to top and bottom boards through the sheetmetal, and fastened the others together on the backside with hurricane straps.
The varnish on the truck had to be scuffed and re-applied every other year due to UV degradation.....I'm not seeing any signs of that on the urethaned bus. I had read that the new urethanes are better than varnish, and it seems to be the case.
Don
The Busted Flush
Old 07-13-2019, 07:29 PM   #18
I'm not going to actually do it (because of the extra difficulty of dealing with wood and the fact that I got into this to learn metal fabrication) but your bus made me do a hard rethink. The wood really looks good on your bus.
Old 07-13-2019, 10:14 PM   #19
HazMatt's Avatar
Chassis: IH 3800, 8 window
Wow! I've got wood!
And I believe if I installed narrow shims between the hull and the planks, it wood negate any rust issues, as water'd run off &/or evaporate just as quickly as a non-Woody bus.
Super spar it first, natch.
Old 07-13-2019, 11:58 PM   #20
Originally Posted by HazMatt View Post
Wow! I've got wood!
I suppose it all depends on the amount of offset between the metal and wood and the protection the gap has from debris. Our bus seems to collect tree "gunk" in th strangest of places due to water running off the roof and down the sides.
