Old 05-13-2020, 04:24 PM   #1
Coachwork: GM- Workhorse
Chassis: P32
Engine: 8.1L Vortec
Rated Cap: 18,000 lbs
Question Workhorse Rails and Framing
Two questions:
1. I'm not seeing any bolts or screws to be able to take off the rails on the floor and sides as pictured, are they a part of the frame and unremovable?
2. After taking off the wood flooring it seems there is only a thin layer of sheet metal where the fireproof foam from under the bus is attached to. If I remove the wood flooring what are some thin, sturdy options I could replace it with?
Waddlebrow is offline   Reply With Quote
Old 05-14-2020, 10:14 AM   #2
Chassis: P32
Engine: 8.1L Vortec
Close up of the rail tracks:
fiberglass, flooring, frame, rails, workhorse
