1993 e-350 collins converted shuttle bus 30ft
I am selling a unique converted short shuttle bus that has been extended to 30 feet. The ultimate tailgate bus or can be converted to a food truck. The bus has a wet bar, queen size bed, futon couch, bathroom with shower, 5 gallon cassette toilet, awning and a college fridge. Separate 5,000 btu a/c mounted on rear wall runs on shore power. Shore power is a generator box connected to 30 Amp fuse box with two circuit breakers. There are several outlets through out the bus. Also has two power inverters to run off 12 volt. There are both fresh and grey water tanks mounted to the frame. There is a passenger seat bolted to the frame that swings out of the way and a foldable two seater bus seat also bolted to the frame with seat belts.
Engine and automatic transmission are not original both have less than 5,000 miles on them. Starter and axillary batteries are new. The bus also has a new fuel pump installed. Both front and rear AC work as does the front and rear heat. Backup camera. Sony car stereo. Brakes serviced last year. Full towing set up including hitch wiring and break control. All lights work. Inspected and ready to test drive.
Sad to let this go but the bus has served us well over the last 5 years. Asking $5,000 or best offer.
