Old 03-20-2023, 04:10 PM   #1
6 Window Skoolie: $27K
Meticulously converted and ready for the van life. Life plans changed and we now must sell. It has never been used as a camper and you would be getting a brand new conversion. Looking to sell for a fair price. We will not get out what we have in it, not to mention the hundreds (thousands?) of hours of labor. It was a fun project I shared with my daughter as it was supposed to be her tiny home. We hope somebody enjoys the love and thought we put into it.
Legal:
  • Registered, Titled, and Insured as Idaho Class C Motorhome
Engine and Base Chassis:
  • 1998 Six Window Collins School Bus
  • Ford cutaway chassis with dual rear wheels
  • Rear passenger side lift door equipped (lift removed)
  • GVWR 14050 (4600 Front, 9450 Rear)
  • 7.3 Liter Power-Stroke Diesel
  • 141K Miles
  • Transmission reportedly rebuilt less than 25K ago.
  • 35 Gallon Fuel Tank
  • Runs well; driven from Florida in January 2020.
  • Strong starter batteries, less than 3 years old.
  • Front tires: 2/2 Good
  • Rear tires: 3/4 fair, 1/4 new.
Conversion:
  • Rear living room design will sleep 3 comfortably.
  • Entry via handicap door with folding 3 step RV stairs.
  • 74 inch headroom, no ducking for modest height folks.
  • Beadboard lightweight T/G ceiling (¼ x 4 inch)
  • Rigid Foam Insulation: 1 inch in floor & ceiling / 1.75 inch in walls.
  • Unique cordwood flooring (don’t ask how many pieces I had to cut).
  • 1925 refurbished farmhouse sink with drainboard.
  • Brass countertop with folding extension.
  • Built in 78 inch couch with storage underneath.
  • Front full size bed.
  • 30 Gallon fresh water tank with standard RV water hookup and bypass.
  • RV 12V water pump
  • 30 Gallon gray water tank.
  • Composting toilet with powered vent (no blackwater tank to empty).
  • For a small RV, a nice size shower/wet bath.
  • Vintage steel lockers (1940s?) for closet and storage.
  • Beech base cabinets in the kitchen.
  • Beech overhead cabinets above bed/driver.
  • Dorm size Magic Chef refrigerator with small freezer compartment.
  • Window Air Conditioner in back.
  • MaxxFan Deluxe 5100K bidirectional roof vent fan.
  • 30 Amp standard RV plug
  • WFCO 30 Amp RV power distribution breaker/fuse/charger panel.
  • 1500W (3000W peak) pure sine wave inverter.
  • Automatic 30 Amp RV transfer switch for Inverter/Shore Power
  • Outdoor GFI plug
  • 540W solar power (2x270) rooftop panels in series (max, 9A at 60v)
  • MPPT 40A Solar Charge Controller
  • Voltage Sensitive Relay (VSR) between starter and house batteries. When the alternator is running the VSR will charge house batteries once starter batteries are full. Also has bypass/jump mode for engine start which ties all batteries together.
  • House batteries: 2 x 6 volt, golf cart, 235 Amp hours, deep cycle (2 years old)
  • House batteries can be charged by converter (shore power), solar panels, or engine when running via VSR.
  • Backup camera that can also be used for rear view mirror.
  • Rear flood lights (not while driving!) for backing into campsites.
00K0K_lrwleqOZN8G_0CI0qb_1200x900.jpg   00K0K_jYjCln2J1sB_0lM0t2_1200x900.jpg   00x0x_l7IJECihzZx_0ww0oo_1200x900.jpg   00606_dm0kN3zeOZS_0ww0oo_1200x900.jpg   00y0y_jyqOrKdMsYp_0ww0oo_1200x900.jpg
00f0f_2zBpA940NHJ_0xH0pw_1200x900.jpg   00J0J_2Cbab3fglnD_0ru0lp_1200x900.jpg   00q0q_jpB5n2prbsP_0ww0oo_600x450.jpg
prh_jax is offline   Reply With Quote
Old 03-21-2023, 11:04 AM   #2
Bus is located in Moscow, Idaho.
Missing info:
6 gallon Electric Water heater, will run off inverter.
complete, e-450, short bus
