Life changes and regretfully, I must pass my bus along.
1997 Blue Bird Flat Front FE
TC2000
27' shorty
Cummins 5.9
AT 545
approx 160k I'll double check the OD.
NO RUST Arizona bus. Painted off white (not yellow!) with no stop arms or signals left. already street legal without needing to delete it all.
I have done tons of mechanical work on this bus. It is solid!! I have driven it over 10k miles myself and would not hesitate to drive it cross country right now!
comes with 5x 250w solar panels, (not installed) and plenty of other things i purchased for the bus can go with it.
just some of the work done:
Torque converter replaced, trans in excellent health (done by AAA Bus)
Fully P&M serviced properly
NEW Drag links and tie rods
NEW fuel line from tank to engine
Freshly rebuilt injectors
NEW steers, drives have some good life left and are in DOT spec
NEW treadle/foot pedal valve
NEW air ride seat bladder
brake cams have been adjusted
old electrical removed and some new wiring added for signals, 4 ways and horn.
heaters are still in tact
This bus has a seat left for a passenger for now and all other old interior junk removed.
It also has E-track in the floor and handi door.
I built a garage wall that is designed to be removable or move up if desired.
So much to say. If intersted please PM me
asking 10k.
currently in central TX with MT registration.
registered as commercial for personal use making the insurance very reasonable through progressive.
Also happy to offer lots of details i have learned and the maint logs i have kept.
rokett
