98 Blue Bird sub 30ft Transit style.
This is a Washington State specked Bus. Pristine condition. With a rear axle change. 4.48 to 3.54...receipts and professionally done. Tires are like new. All maintenance and all fluids and filters. This is a turn key bus and used twice since the axle change. It is located in Vancouver Washington. And yes it has the
Cummins 12 Valve 5.9 turbo.
This is an excellent example of this Model. As mentioned turn key. Axle ratio was not changed out of any failure of the original.
But by design; to ensure less heat and tension and a quieter, more efficient and enjoyable bus at highway speeds. This bus cruises at 70-75 at 2150 RPM.
Governed at 2400. Turn key opportunity.
I will upload more images later.
It has been used twice since work done. Transport my motocross bikes to two tournaments. It is an unmolested interior. First buyer at $8509.00. Bus will be offered on other formats. Bus will go quickly. Price ls firm. Sorry dreamers🤣 Firm
