bus conversion for sale
Asking 15,000. Located in edgewater Florida. 2007 Frieghtliner champion 35' city bus partially converted. Sleeps 6 all memory foam beds. The queen size bed is 14 inches thick. Over 700 watts in LG solar panels. Ecoworthy all in one solar inverter charger. 24v 300 amp hour lithium battery. 120v outlets. 30 amp rv shore plug. 100 gal fresh water tank with external gravity fill hookup. seaflow water pump. Excel on demand water heater. Full size Double chamber stainles steel sink and residential Glacier Bay faucet. Propane 4 burner cooktop on a Teak countertop. Composting toilet w/urine diverter plumbed to 100 gal grey water tank that is mounted under the bus. Has 3 inch rv waste valve to make dumping easy. Rear engine pusher ISB 260 Cummins 5.9 diesel runs great paired with allison transmission. Odometer reads 19k miles but actual is believed to be under 150,000 miles according to hub odometer
