Old 12-13-2023, 08:46 PM   #1
Caterpillar 3126E, NO DEF, 7.2litre mated to Allison MD3060 (130k miles)(6 speed)
Open to offers.
Parting out the Thomas 2004: Location is Fort Worth, TX
Engine has approximately 70K miles (documented, see photos).
Engine and trans computers included Cooling package.
Engine is currently installed in a 2004 Thomas Saf-t-liner. Price does NOT include removal, however removal is negotiable.
Located in Fort Worth, TX.
More photos available upon request.
Engine Type Cat 3126E, Inline 6 cyl, 7.2litre
Valves Pushrod driven 2 Intake, 1 Exhaust
Compression Ratio 16 to 1
Fuel System HEUI
Water Pump Belt Driven (V belt driven)
Oil Pump Gear Driven
Engine Serial Number HEP07770
Build Date Oct 14 2002
Build Location Greenville South Carolina
Hp Rating 275hp @2200RPM
Torque 800 lb ft @1440RPM
High Idle (redline) 2640RPM
Fuel Type Recommended Diesel #2 (#1 in cold weather)
Oil Capacity
Oil Type Shell Rotella T4 15w40 (NOT Synthetic)
Oil Filter 1R-1807
Recommended Oil Change Interval 10,000 miles or annually
Valve Lash Adjustment 100,000 miles (.015" Intake, .025" Exhaust)
Filter Gp w/ Water Separator 175-2949
Primary Fuel Filter w/ Water Separator 198-6378
Fuel Filter Secondary 1R-0751
20231003_094153.jpg   20231003_094014.jpg   20231003_094101.jpg   20231003_094913.jpg   20231003_095001.jpg
airfix4 is offline   Reply With Quote
Old 09-11-2024, 03:35 PM   #2
Hi, wondering if the bus is still available for parts.
looking for an instrument cluster or dash assembly.
Frank
B3-514 is offline   Reply With Quote
allison 3060, cat 3126, documented, low miles
