Old 08-10-2023, 10:23 PM   #1
fo4imtippin's Avatar
Chassis: TC2000 28ft
Flasher Delete Headlight Housings For Sale
I had these light housings 3d printed for both the front and back of my bus. I ended up only using the fronts. They were made to fit over the holes in a High Roof All American, but will fit many more if you cut bigger holes in the back like i did.
These used 6kg of ASA filament. They are for sale for $150 shipped. They will need sanded, primered and painted before screwing on.
Old 08-14-2023, 10:18 PM   #2
I'm interested, do you have a measurement on them? Also do they aim the light downward at a angle or straight forward?
Dezrik is offline   Reply With Quote
Old 08-16-2023, 08:49 PM   #3
Measurements
They don't have any tilt to them, but it wouldn't take much of a shim on the backing plate, or when you set the headlight in.
They are made to fit the 7in jeep headlights, although i had to sand the inside of mine down a bit after i got my light and it was 7.05in. around.
I wouldn't advise to use them as headlights, i was thinking to light up a forest road or something and i really like the look of the halo around the headlight.
Old 08-16-2023, 09:02 PM   #4
I plan on using them for lighting on forest roads and while parked off grid potentially.
Here's a picture of my bus before the roof raise.
Old 08-23-2023, 12:26 PM   #5
Ill trade you the light housings for the 4x4 bus straight up! Let me know if we have a deal! haha jk. Sweet ride, but i think your going to want to light up the forest roads. Looks like you need a winch too!
Old 11-12-2023, 02:04 PM   #6
Chassis: MVP ER
Do you happen to have the cad file for these?
ism minerals is offline   Reply With Quote
