Old 01-25-2024, 08:06 PM   #1
Year: 1965
Coachwork: Gillig
Engine: Cummins C190
For Sale 1965 Gillig conversion 35"
Up for sale is our 1965 35' Gillig School Bus Motor-home conversion. Broken Cummins C190 Diesel motor.
Last time out it encountered an engine problem and had to have it towed home. Found water in the oil so most likely it has a blown head gasket and worst case cracked head. Been told by many qualified persons that the head can be repaired/welded and milled. This is a perfect opportunity for the person with desire and capability to fix this motor and get out on the road in this classic beauty.
Asking $8000, have over $15000 invested and 4 years work on her. Here's a list and pictures of what you will get.
New updated interior
• New carpet
• Paint and wall paper
• Plumbing fixtures
• 2 TV’s, one with HD antenna in front of bus and one with Blue-ray DVD in BR
• Blue-tooth stereo
• New LED lighting, interior and exterior Brake, Turn signal and Marker lights)
• Engineered hickory flooring in the kitchen
• 5/8 bamboo flooring in the bathroom
• Airhorns that are sure to be heard
• Teak dresser with pull out drawers to make loading and unloading a snap
• All new cellular window shades, light filtering in general areas and blackout in bedroom
• Numerous lighting options in both 12vdc and 120ac
• Oak dining table and chairs
• Underbed storage
Exterior and running gear
• Freshly rebuilt Allison Transmission (Rebuild cost $5000)
• New tires all around (Less than 100 miles ago Cost $3000+)
• New Coleman Park Model A/C (basement model $994.00)
• New Eagle Flight Wheel covers ($500)
• Accuride steel armor coated wheels
• New air compressor for airbrakes
• Roof coating 3 years old
• All new brake, turn signal, marker front and rear and side marker LED lights
• New backup camera
• Ample of storage
• 4.5Kw Kohler Generator and 7kw inverter
• 2 8d deepcycle batteries
• Solar array ready with charge controller
I have loaded the max of 20 pictures as attachments
bills65gillig is offline   Reply With Quote
Old 01-25-2024, 08:32 PM   #2
Year: 1965
Coachwork: Gillig
For ale 1965 Gillig conversion 35"
Here are some more pictures
Old 01-30-2024, 01:53 PM   #3
ChallengerExpress's Avatar
Can you please call me? I'm interested 408-326-9472
ChallengerExpress is offline   Reply With Quote
Old 02-01-2024, 01:17 PM   #4
Year: 1965
Coachwork: Gillig
I sent you a text with ph# to give me a call
Old 02-01-2024, 01:22 PM   #5
Year: 1965
Coachwork: Gillig
Unable to reply to PM due to Skoolie restriction.
Old 02-03-2024, 04:13 PM   #6
sportyrick's Avatar
Chassis: F33695
Very nice bus for the money even if it needs and engine, shame to see you get rid of it.
Old 02-04-2024, 07:34 AM   #7
looks like a really nice rig. (other than that frig seems like a killer projectile in the event of a brake slam).. awesome inside and the gilligs were built extremely solid to last!
Old 02-04-2024, 03:32 PM   #8
Year: 1965
Coachwork: Gillig
With regard to the refer. It is set in a steel channel bolted through the floor into steel structure, and the back side is solidly attached to the bathroom wall. and the cabinet above has zero clearance to keep it from moving upward.
It was a beast to get it in when I replaced it a few years back
Old 02-04-2024, 03:51 PM   #9
Year: 1965
Coachwork: Gillig
attachment of refer installation
I can't get these photos to attach correctly with out the rotation
Old 02-04-2024, 04:49 PM   #10
Chassis: VIN = 1T7HR3B2311090770
Rated Cap: ~72
Insulation overall is . . .
. . . what?
TaliaDPerkins is offline   Reply With Quote
Old 02-05-2024, 10:44 AM   #11
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Attachment 76259
Attachment 76260
Attachment 76261
Attachment 76262
Attachment 76263
And this. to me, is exactly what building/driving a skoolie is all about. Being able to do things like this to get exactly what you want without having to compromise in other areas.
Albatross is offline   Reply With Quote
Old 02-05-2024, 12:32 PM   #12
Year: 1965
Coachwork: Gillig
I will take it that your referring to the installation and not the orientation of my photos.
Thanks
Old 02-05-2024, 01:03 PM   #13
Year: 1965
Coachwork: Gillig
Insulation: The roof insulation is as installed at the Gillig factory. The sides have fiberglass R20 insulation and none in the floors/basement other than what is provided by the flooring
Old 02-07-2024, 03:40 PM   #14
I’m down in Oregon. Maybe not too far from you. Can I talk with you more? My number is 5035837592. - Blayne
B&B Bus is offline   Reply With Quote
Old 02-07-2024, 03:43 PM   #15
Year: 1965
Coachwork: Gillig
Sure Ill give you a call in about 2:30 time
