Old 12-08-2024, 04:25 PM   #1
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
FS: engine driven air conditioning system
Two of everything, compressors, condensers, and exchangers. Pulled from a working bus but I haven’t tested any of it myself. $100, you pick it up in Toledo OH or I may be able to deliver within a 3 hour radius for a fee. If it’s not gone by January 1 2025 I’m scrapping it.
dbsoundman is offline   Reply With Quote
Old 12-08-2024, 08:06 PM   #2
did you take the brackets off the engine?
Old 12-08-2024, 08:19 PM   #3
Year: 2006
Chassis: MVP-EF
I don’t have the compressor brackets. I believe this came off a cummins bus, hence the particular compressor style. I know cat engines used an ear mount compressor with a different bracket.
Old 12-08-2024, 09:01 PM   #4
I was wondering... they look like GMC A6 style compressors ... this setup was real common on TC2000's with 5.9. I was asking as i have a friend looking for a setup for a 5.9.
if no one else buys this equipment then I will buy it ,check with me before you scrap it
Old 12-28-2024, 10:17 PM   #5
Coachwork: IC/Amtran
Chassis: 2001 International 3800
Rated Cap: 26000
Would this work on a 2001 International/Amtran FE DT 446E?
GillyGoGo is offline   Reply With Quote
Old 12-29-2024, 05:33 AM   #6
The evaporators and condenser yes they are universal pretty much but you’ll need a compressor bracket and a sanden SD7 enhanced compressor ..
Old 01-05-2025, 09:26 PM   #7
Rated Cap: 26000
Still have this? I didn't see your date of scrapping, I would be interested in the condensor if you still have it.
