FS. Two 24V 63AH Li-Ion batteries
For sale are the two lithium ion batteries I have had in my bus for the last 3 years.
Purchased used out of a crashed Fiat 500 E, these two packs have served me well of the years.
Max charge OCV is 25.2
6S of Samsung SDI 63Ah cells.
Very high quality cells
The pack has lived an easy life always had the charge and discharge limits set to 20-80% range.
Max voltage set to 80% 24.0V
Discharge set to 20.5V
Always connected to a BMS With active balancer, located insulated area of the bus.
Capacity test I performed May 2022 showed 2.55KW available from the battery pack ( both packs in parallel ) with these settings. ~~ 105 AH.
I estimate the battery health to be 85-90% with very little degradation occurring.
All cells balanced perfectly at 3.998-4.000 V
Dimensions are 7"X6"X11"
Two available
