Old 03-27-2022, 09:03 PM   #1
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
FS: Webasto DBW2010 "Scholastic" diesel powered coolant heater
Hi all, I had thought I would do some sort of hydronic heating with my bus, but I decided to go a different direction, so I've pulled this Webasto unit for sale. It worked great when I took my first camping trip and I ran the bus heaters to warm up the interior, but after that I couldn't get it to ignite. Further investigation led me to believe the fuel line going into the Webasto from my fuel tank was clogged, but I can't guarantee that's the issue. There's a series of other troubleshooting steps that can be taken to get these things going, I'm pretty sure it can be fixed without a crazy amount of effort (assuming a clogged fuel line wasn't the issue to begin with!).
What you see is what you get: the main Webasto unit, less mounting brackets, exhaust pipe, wiring harness, and I also have the copper floor flange connectors for intercepting the bus' coolant lines as well.
The main unit isn't light, but it's not hundreds of pounds; I can weigh it later this week but I suspect it would be best to ship this freight, or via Greyhound. It could be boxed up and shipped FedEx or UPS but that would likely be pretty spendy.
Asking $400, I don't see a lot of these up for sale. I'm happy to consider offers! I will be making a trip from Ohio to Miami FL at the end of April - beginning of May so there's some possibility of delivery in that time frame.
22-03-26 15-51-56 5353.jpg   22-03-26 15-52-19 5354.jpg   22-03-26 15-52-24 5355.jpg   22-03-26 15-52-32 5356.jpg   22-03-26 15-52-42 5357.jpg
dbsoundman is offline   Reply With Quote
