Old 03-26-2023, 05:18 PM   #1
Fully Converted Skoolie for Sale
We are selling our beloved bus! This bus was a labor of love and needs absolutely nothing in the way of conversion. It's ready to rock! Totally off grid, tiny house, skoolie living. Listed below is most of the nuts and bolts of the conversion, but please feel free to reach out if you have any questions on the build.
1995 Genesis Amtran Flat-nose Schoolie. 30' overall length.
International DT466 Mechanical 190HP Diesel Engine
Factory Remanufactured AT545 Automatic Transmission professionally installed 08/2019
187,xxx miles
100% converted
Registered as Private School Bus in California with CA plates. Registered through 09/2020 (FYI, there are no late fees for expired registration on Private School Bus).
Bus is located on our property in Craig, Montana. We are located in Southern CA.
Asking $40,000
Electrical/ Solar -
Two Sunpower X21-335 Black solar panels for a total of 670 Watts of solar
Four Crown CR-235 6V batteries for a total of 470ah of battery storage
Batteries were purchased NEW 05/2019. Never discharged below 75%.
Morningstar Tristar TS-MPPT-60 amp Charge Controller with digital meter
Trimetric TM-2030 Battery Monitor
Dual inverter system includes Victron 1200 Inverter with Remote Switch - for running all outlets/ Dedicated Victron 500 Inverter for running DaeWoo 4.4 Cubic Foot fridge
Water -
100 Gallon fresh water tank
two - 35 gallon gray water tanks (one tank collects sink water, the other collects shower water)
Eccotemp L5 tankless water heater
Nature's Head composting toilet
Gas -
Dual 20lb. removable propane tanks, mounted in exterior propane box with automatic switchover regulator
Copper lines throughout providing gas to: 2 burner range/ oven
4,000 BTU portable ceramic heater (can also run on two 1lb propane tanks for increased portability).
Furnace -
Diesel heater with remote with the fuel line plumbed into the main tank and pump outside. No A/C.
WHAT IT NEEDS:
1- Front driver side tire has a very slow leak. It loses about 10-15 pounds of pressure per month.
2- On our last road trip, the alternator started sporadically putting out max voltage. It was occasional and intermittent, but may be signaling that a new alternator or voltage regulator will be needed in the near future.
Please email or PM with any questions. We live in Southern California. The bus is located at our property in Craig, Montana. I have plans to be in Montana Mid-May and can meet you then... unless you are a VERY motivated buyer. Perhaps we can arrange a trip sooner.
PM with any questions or to arrange a time to chat.
theavgs is offline   Reply With Quote
Old 05-02-2023, 10:14 PM   #2
We will be in Montana 05/20-05/23 and available to show the bus at that time. Located in Craig, MT.
