Old 12-09-2019, 02:15 PM   #21
Originally Posted by cdrobbins77 View Post
Thanks. I have one more local guy to try. If that falls through i will let you know. 24 pcs hat channel at 16", 24 pieces C channel at 36" ish.
I'll get a weight for you, PM your address.
Old 12-09-2019, 03:27 PM   #22
16" Hat and 36" C weighs 4.4lbs. Choose your shipping method.
Old 09-02-2021, 11:49 AM   #23
25% off listed prices while supplies last.
Old 09-02-2021, 12:09 PM   #24
[/QUOTE]
Quality work, I would highly recommend to anyone doing a raise to buy now while you can. Prices are going up nationwide
IC08 is offline   Reply With Quote
Old 09-02-2021, 01:03 PM   #25
Make sure to get enough C channel as well to connect both sides of the new hat channel to the old. Example below
EDIT: actually I would remove my image if I could (not sure how) 01marc's image is a much better example. Still highly recommend!
I recommend at least a 6" overlap.
Use the "Edit" option to remove parts of your post. It's only available for about an hour after posting then the edit option goes away.
Old 09-07-2021, 12:49 PM   #26
Chassis: 2000 Int Amtran
Engine: DT466HT
6 total, or 6 on each end of channel
MacC is offline   Reply With Quote
Old 09-07-2021, 01:01 PM   #27
6" on each end. 3" on each end puts you in Colorado Custom Coachworks territory, who we all make fun of.
Old 09-07-2021, 01:08 PM   #28
Engine: DT466HT
Thanks for info.
Old 09-07-2021, 02:24 PM   #29
I would go 6" each end, material cost may save a few dollars by going 3" and would maybe be sufficient.
