Originally Posted by Oldyeller
I looked at the other thread and had some questions.
Where are you in California?
I am located in Joshua Tree
Does your drivetrain have electronic control or is it entirely mechanical. I noted someone suggested that by 2003 it would be electronic.
Yes electronic.
Confirm AT545?
Yes AT545
Did you put the tires on it that you pictured? The lugged in the rear?
I put the tires on new. Yes lugs in the rear. less than 10k on them.
What is the overall length of the bus?
Overall length around 34 feet.
Rear end ratio?
I will check. It's not the higher of the options available that year.
How much of the interior is done at this point?
Bed and cabinets in the rear, rest is open.
Price? Make reasonable offer.
100 watt solar panel and 3000 watt inverter. Diesel heater, transmission cooler, new thermostat, new lift pump, fresh fuel filters, flatface front wheels, backup camera, Android stereo and 4 6x9 speakers, Wifi, navigation, video, registered in California as 2003 Blue Bird Wonderlodge.
