Old 03-18-2021, 09:11 PM   #1
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
Intermittent Wipers - Want to buy
2000 Amtran/IC with dual wiper motors. Looking for a wiper switch with intermittent / low / high and park.
Steve
Old 03-19-2021, 06:55 AM   #2
lots of these switches end up crushed in busses at the junkyard all the time.. id look around for a truck / bus junkyard if you arent looking to buy new. if looking to buy new there are lots of places that sell them but they arent cheap. I havent seen a switch for a bus that has a separate park position on the switch, the motors typically have one of a couple different park mechanisms built in. from what I have seen it looks like the Amtran / first gen IC. conventionals use the same wiper switches as the flat nose. some busses have 2 switches others are a single switch to control both motors (the switch is often a 8 wire for the double motor control. some of them have a sepasrate wire for the ewasher pump.
Old 03-19-2021, 10:19 AM   #3
ewo1's Avatar
I just posted a very simple circuit that can be easily built in this thread. post #8
https://www.skoolie.net/forums/f9/in...tml#post431176
amtran, dual motor, intermittent, wiper
