Old 02-25-2024, 06:01 PM   #1
joeblack5's Avatar
Year: 98
Low floor city handicapped conversion for sale. 2003
Hi folks, we are looking into selling our low floor bus with handicap ramp.
Bus name is Dory and you can see our travels across the USA.
Dory has a Mercedes om906la with a b300r Allison in the rear. 6 th gear is unlocked. No leaks, no smoke. No egr no def.
Dory has floor heat with a webasto tsl17.
Dometic 12 volt fridge.
Induction cooking.
Microwave small 600watt.
Small electric convection oven.
40 gallon water.
Stainless shower stall with recirculating shower head.
Toilet chair .
16x 75 watt solar panels.
4 mppt charge controllers.
1 double bed in the rear above engine,
1 bunk in raised rear behind rear wheels.
1 fold out couch/ bed in front.
1/2 dinette with a captain swivel chair.
Large windows that swing open and have a second lexan pane on the inside.
The kitchen is in the front area above the wheel wells. On the drive side.Stainless counter top and backsplash, stainless smoke hood and super insulated domestic fridge. On the passenger side is a wooden countertop with stainless sink. .
Price idea $30000
Check the build threads.
pm with questions
Johan
This bus is on good shape
2 pure sine inverters, 3500 and 3000 watt.24 volt.
Old 03-01-2024, 09:42 AM   #2
Does the engine run and when was the last time you drove it?
Do you have photos?
Thanks.
tguy1241 is offline   Reply With Quote
Old 03-01-2024, 10:20 AM   #3
joeblack5's Avatar
Year: 98
Drives great, last time was cross country to the southwest Arizona/ california, 11 months ago. See our Dory trip report.
For photos see our Dory build threads.
We towed a small econoline 4*4 bus to skoolie palooza.
The bus sits on blocks as not to collapse the airbags to much.
Johan
Old 03-01-2024, 03:09 PM   #4
So it has been up on blocks for 11 months? Has the engine been turned over during those 11 months? Why would the airbags collapse from sitting on the tires?
How about some photos?
Old 03-01-2024, 08:40 PM   #5
joeblack5's Avatar
Year: 98
No use to turn the engine over unless you want to warm it up.
As the air from the airbags disappears the bus settles on the bump stops inside the airbags. The rubber of the bags would be creased for a long time and potentially weaken. For that reason it is better to not allow the bus to settle for a long time in its lowest position. Hence there are blocks under the frame that keep the suspension uncollapsed.
Tguy where are you located, why are looking into a low floor bus? Did you find the build threads of this bus?
Johan
