08-04-2020, 11:08 PM
Chassis: F33695
Parting 05 BB
Parting out 2005 BB, Im keeping the C7 Cat engine, most everything else is available. 2000 Allison w 255,000 miles and works great, 5.29 rearend w juice disc brakes, front axle with juice disc brakes, frontend is ok and could use a little paint, newer 2015 radiator or if you need a "pole" repair set buy the frontend, intercooler, radiator and bumper, front door is good, what ever you might need pm or email me, fuel tank is good, back door is nice, some tinted windows, did you know these 05 tinted windows fit my 1976 All American! new mirrors too, dash, seats anyone, I'm sure there are things someone may need that I haven't touched on. wells7500@att.net
08-05-2020, 06:29 AM
I like those Gen 1 visions.. why destroying it? definitely save the computers out of it.. engine, trans ,etc.. try to be nice to the wiring harnessers.. anyone wanting to do an allison 2000 swap into another bus will want the special wiring harness that goes to it.
08-05-2020, 09:31 AM
how much for the transmission with complete wiring harness and TCM?
08-05-2020, 10:20 AM
Chassis: Tc2000
Engine: 5.9 24v
Rated Cap: 27
Can I get you to measure your Entrance door glass please?
I have a 02 BB TC1000 handi bus. I need just the lower door glass, mine measures 12 1/2" X 48" approximately.
Is yours an air door? If so I would also like the air cylinder that operates the door. I'll check on the part number to make sure it is the same cylinder.
08-05-2020, 11:12 AM
Chassis: Tc2000
Engine: 5.9 24v
Rated Cap: 27
Also what size is your fuel tank?
08-05-2020, 10:08 PM
Chassis: F33695
60 gallons I think, I'll have to look at build sheet
08-05-2020, 10:12 PM
Chassis: F33695
Who's gonna pull it, you or me? I'll let you have everything you need, shifter, computer, wiring, mounts for $250 if you pull it, if I pull it all $500 plus freight.
08-05-2020, 10:20 PM
Chassis: F33695
Looks like @11x24 top and @11x51 lower, what if you just bought the whole door, It's 85 1/4x29, no air cylinder.
08-05-2020, 10:30 PM
Chassis: F33695
Cadillackid I need the engine for my service truck even though it has issues, I will rebuild and then swap it into my GMC 7500 so I am not down long. Ya it's really a pretty good bus but then they are a dime a dozen aren't they. Tires are shot, batteries are shot, juice brakes don't work right, did come with a half tank of fuel, has oil in the coolant so have to find out why, that's why I got it cheap. Service records say it got a radiator in 2015, I think they got it hot and cracked something, shame cause it runs great. It would be nice if I could just put it in my truck straight up and not go thru it before hand.
08-06-2020, 11:35 AM
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Allison shows “SAE#3 CONV HSG W/MAN (SAE” so I’m assuming that this trans has the SAE #3 an AT545 has. To put this in a 98 Thomas International currently with a 545 and DT466E then someone would need an ECM and a TCM from an International with the 466 and 1000/2000? Also special wiring harnesses?
08-06-2020, 12:06 PM
Chassis: Tc2000
Engine: 5.9 24v
Rated Cap: 27
Thanks on the door specs, none of your glass is the same size as mine and at 89" tall your door is 9 inches taller than mine, so I guess none of it will fit.
Regarding the tank, I have a 60 and am looking to go bigger, so another 60 isn't super helpfull.
Thanks!
08-06-2020, 09:23 PM
Chassis: F33695
Bamabus:
That is over my pay scale, maybe Cadillackid could answer that. Having just completed a conversion of a 3060 myself I can say on the 1995 era Allison it didn't matter what engine it hooked up to it just needed a throttle cable hooked to the TPS on the transmission. This is a 10 year newer transmission so it might be different. I will be able to tell more when I pull the engine and tranny and get a visual on the engine hookup. Bellhousing SAE size???
08-20-2020, 08:38 AM
Year: 97
Engine: T444e
Rated Cap: 25,500
Is the transmission still available
08-24-2020, 12:09 AM
Chassis: All American RE
Engine: Caterpillar 3126B
Just curious, why don’t you just go to an automotive glass shop and have them cut you a new glass panel? I cracked one when I was fixing our bent door, and it only cost around $50.
08-24-2020, 12:11 AM
I may be looking for regular windows to replace the emergency windows in our 2000 All American. Need tinted, need two 25” wide and two 32” wide. I’m in 2.5 hours east of St. Louis, might be worth a drive.
08-27-2020, 08:45 AM
Chassis: F33695
yes it's still in the bus and could be driven as I haven't had time to pull engine yet.
08-28-2020, 06:11 PM
Chassis: F33695
CoffeeGuy:
I sent you a message.
