Old 02-08-2023, 12:13 PM   #1
Chassis: Carpenter SB 2508
Engine: Navistar DTA360 disel inline 6 cyl, 5.9L
SALE-1992 International DT360
I am reluctantly leaving the Skoolie life due to health issues. My wonderful green bus is now for sale - please see details below. I am currently in FL and will be at the Skoolie Swarm in mid-Feb. Asking $35k OBO. FYI: I don't always have good connectivity, so please be patient; I will respond to all queries.
1992 Navistar (International) DTA 360, Model #3800
Diesel inline 6 cyl, 5.9L
Carpenter body: SB2508
Mileage (as of 1/31/2023) 70,030
Five-speed, manual
New clutch (January 2023)
Hydraulic breaks (fluid bled & replaced June 2022)
All new tires (2021)
New steering gear (2021)
Regular preventative maintenance (paperwork provided, last one 1/02/2023)
Licensed as an RV in Minnesota
Rear back-up camera (+ two side cameras, wired but not hooked up)
Roof painted with Henry’s insulating elastomeric paint
Inside stripped bare, rust-proofed, then painted with Rust-oleum
Ceiling insulated with Havelock wool
Floor and walls have 2” XPS closed cell plank insulation (gaps filled with foam &/or Havelock wool)
All metal hat-rails and side wall-rails have frost barrier covering
¾” marine plywood subfloor
½” plywood walls
Vinyl plank flooring (extra planks included)
Pine beadboard ceiling
Kidde smoke & C02 alarm & Fire extinguisher
Electric professionally installed (by licensed marine electrician)
380w solar (2 – 190w panels mounted on roof)
MPPT 100 | 50
Xanterx 2000w inverter
Victron battery monitor
Two AGM batteries – undercarriage compartment; + charged by alternator
30amp shore power hookup (cord with surge protector included)
Built-in wooden channel-run along both sides of ceiling/wall edges for easy access to electrical wires
Four electrical outlets
Undercarriage LP tank carrier (two LP tanks with regulator included)
One undercarriage storage bay (currently used for sewer hoses - included)
Diesel heater (installed, but never used)
Nature's Head composting toilet
One 42-gal fresh water tank (mounted under the bed)
Two 28-gal grey water tanks (undermounted to frame; for sink / shower)
Shur-flo water pump and accumulator tank
Pex used throughout; braided pex from tank/shore hookup to water pump
Shore water hookup (potable water hose included)
Ecco-temp i12 LP on-demand water heater (120 v, <12 amps)
Two Maxx-air ceiling fans with remotes
Nectar Hybrid full-size mattress
Insulated curtains throughout
LED lighting throughout
Window screens
22’6” from back of driver’s seat to back of bus (bed 54” wide)
7’8” wide (side to side)
NEEDS WORK
Front steps, dash and driver’s seat area
Entry door & lock, and rear door lock
Broken window clips on a couple windows (prevents them from opening)
Dinette table is temporary – should be replaced
Kitchen faucet head needs periodic soaking in CLR due to hard water buildup
Engine belts scheduled for replacement at one of the next PM’s
Label on the electric panel for diesel heater
Replace batteries in smoke alarm
Better lock on closet doors
A few pieces of flooring needs to clicked into place
A little rust inside bottom of back exit door
Small hole (2-3"), in left-side hood fiberglass (been there for years)
More details upon request. I've been full-time on the road for nearly 2-years. Possible delivery in Midwest if near my route back home (MS to MN). I'd love to keep traveling, but progressive arthritis is making it impossible.
Kathy K
Bus-exterior-passengerside-2.jpg   ElectricPanel.jpg   Drivers-seat-2.jpg   Interior-bedroom-door-open.jpg   Closet-interior.jpg
Kathy K
Kaklehr is offline   Reply With Quote
converted bus, international 3800, sale
