Old 02-18-2021, 03:42 PM   #1
Save a Crown Supercoach 1980 - Poughkeepsie, NY
hello everyone,
I'm very sad to let my amazing bus go but the reality is that I wasn't able to take care of it anymore in recent years. I'll tell you the full story and perhaps this you'll find this a worthwhile project to take on.
In 2017 my partner at the time and I bought a very well maintained crown super coach (it was used in Northern California - had two owners, the school district and the second owner was actually the former bus driver that used to drive it every day). We bought it move our belongings from CA to NY and visit the black rock desert on the way.
About a year after settling down in NY instead of staying there and eventually finishing the conversion I ended up moving to Germany where I have been since and the bus has been on a parking lot in upstate New York since. It hasn't moved since but is in remarkably good condition as it was far away from salt and east coast roads. We painted the bus with oil paint in almond and pulled out the original benches and registered it as an RV. But it still is very much a blank canvas.
The good:
* The body and engine is in very good condition - never had an issue starting it or anything else for that matter
* It comes with 3 extra windows, a bunch of gaskets for the wheel wells, an extra compressor and more spare parts
* It has automatic snow chains (how cool is that)
* Has a 3 axles, the rear two axles can be locked, perfect on snow
* It's a big cam engine
* No rust on the body, well intact floor (no rotten floor boards)
The not so good but fixable stuff:
* Small current leak draining the battery if you leave it plugged in for > 2 weeks
* Slow coolant leak - after about 9mo of storage it started to run low
Who's interested in taking on this project?
https://imgur.com/a/XjcXoJq
sfluke is offline   Reply With Quote
Old 02-18-2021, 03:48 PM   #2
Nice looking crown and some great mechanical attributes. I just shared this on the Facebook Crown Coach Junkies group page. I'd love to take this on, but we're already a bit backed up with buses and I just came home with a Crown a few weeks ago. My wife would not be pleased if I brought home an other one right now...but darn, this is tempting!
Old 02-18-2021, 04:15 PM   #3
How much are you selling it for?
Sabrinalyon is offline   Reply With Quote
Old 02-18-2021, 04:20 PM   #4
Chassis: International 1753
Engine: 6.9 International
You forgot to put a price on this very well maintained amazing bus.
Or is it free for whoever is willing to give "salvation" to it?
Old 02-18-2021, 04:20 PM   #5
Can you provide a picture of the data plate? Should be under the driver side window on the left. Thanks!
randallg30 is offline   Reply With Quote
Old 02-18-2021, 04:54 PM   #6
What's the price??
Wear A Mask- Stop the Spread!
Old 02-18-2021, 09:33 PM   #7
That same question was posed in the Facebook Crown group...what's your asking price? I'm happy to relay that info to them, over there. There's definitely interest.
Old 02-18-2021, 10:22 PM   #8
Crown_Guy's Avatar
Coachwork: Crown Coach
Chassis: 40ft 3-axle 10spd O/D, Factory A/C
Engine: 300hp Cummins 855
Rated Cap: 91
Originally Posted by sfluke View Post
hello everyone,
The good:
Looks sharp. Amazing how all those words still don't convey very much actionable information about this Crown.
Little things like:
Exact engine, which he hints at being a Big Cam (Cummins), and 1980 makes it probably a Big Cam II, maybe 290, maybe 300. Would like to know that more accurately.
Transmission is a BIGGY for many folks. Make or break, actually, if they don't want, or know how, or want to learn how, to shift the beasty.
5spd manual, flat land School District slug, or a more sporty 10spd mountain configured beauty, maybe even with a Jake, (drools). If mountain bus it may even have some nice goodies like sanders, or electric heaters for engine oil, coolant, maybe even automatic chains....Oops it does have that. It's sounding more and more like a mountain bus. Interesting
If Automatic, will be an Allison, maybe an MT64X but most probably an HT740 to better handle that big Cummins torque, which will be about 1000ft/lbs
Rear axles suspension?? Air-ride or springs, potential buyers want to know.
We can assume it has the normal rear-end ratio of 4.10 which gives a road speed of about 63 or so at about 2200 engine rpm. One neat thing about the Cummins is that they will go higher in rpms without shutting down hard like the Detroit governors do, so you could probably get a decent 66 mph out of it at a higher rpm for a good highway cruiser.
Depending on what the transmission is you can only get higher road speed with a rear-end differential gearing replacement, to something like 3.9 or 3.7:1, and with the two of them needing to be changed, that's not going to be very cheap.
He mentions that the rear axles lock up. This means it has power on both axles with an inter-axle differential for use on-highway, but when locked together gives much more traction on snow, ice, mud conditions. It also verifies that it isn't simply a tag axle arrangement where only one axle has power and differential and the other one is only used to carry the vehicle weight. I've seen plenty of these around and about too. It was all up to how the original buyer spec'd and what they wanted Crown to install. This sounds more and more like a mountain bus setup. Northern Kalifornia, after all. Or as I would prefer to call it: the "State of Jefferson". One can hope anyway.
If it's a manual shift, whatever, where 5th or 10th is a direct 1:1 output ratio you could re-fit/convert it or simply replace it with an over-drive transmission where the output in high gear is now about .87:1 which would give you an honest 70+ highway cruising speed and probably as much as 80 with little trouble.
By the way the Cummins prefers to turn much slower and they like it around 1500 1700 rpms, so a high geared rear-end won't hurt the engine at all, unlike the Detroits which need to be kept at around 2100 all the time for proper power, cooling, and overall longevity. But I get distracted.
Any other things about it would be nice, but I think I covered the critical ones for a buyer to want to know. Other than that it looks like a good catch if the price is reasonable........
That would be nice to know too. I have a pretty good idea what the Crowns are escalating to price wise but I'm not going to say anything here except to say that a decent Tandem, especially with a good Cummins, is in high demand for a certain type of buyer. Let the fun begin.
Crown_Guy is offline   Reply With Quote
Old 02-19-2021, 12:13 AM   #9
Sfluke please pm me at jaws69@hotmail.com with details about you Crown...price most important but PowerPoint tranny type would also be nice. I have cash in hand if price is right. Thanks
Jaws1960 is offline   Reply With Quote
Old 02-19-2021, 08:01 AM   #10
Looking at the pictures, it has an automatic. Easier to drive but not as much fun, lol. And as mentioned w/out a gear change the speed will be limited to low to mid 60's mph. Too bad though, a 10spd Tandem with a Cummins would have been close to a unicorn.
Old 02-19-2021, 08:06 AM   #11
Interested, what's the price?
mcduffieja is offline   Reply With Quote
Old 02-19-2021, 08:16 AM   #12
Yup, looks to be the H series shifter.
One of those old Ht series allisons had an OD gear, was it the HT70?
That might help with the top speed, vs having your typical 1:1 in most transmissions.
But all is worthless without a price. Nobody knows if it's 2k or 20k.
Old 02-19-2021, 07:04 PM   #13
Crown_Guy's Avatar
Rated Cap: 91
OOps. I'm a dope. I didn't notice the extra pictures link and only saw the one in the posting. Yep. It's an automatic, but you can't read too much into which model Allison it might be just from the shift controls. I've seen various types, styles, and manufactures of those shifting quadrants, and they were all controlling various Allisons, mostly MT64X's in most Crowns due to the engines in use. That particular setup I prefer and have used more through the years and would prefer it over the others I've run into, but it still could be controlling any sized transmission. Lets see if the OP ever gets back to give us a price...... It would be nice if he could answer some of my questions though. He may not really know, to be fair to him.
Old 02-19-2021, 07:13 PM   #14
Engine: TE 444
Rated Cap: 12
hope it is not a MT643, they can only handle about 250 HP and 700 ft lbs of torque
Old 02-19-2021, 07:14 PM   #15
Indeed...getting some update from the OP would be nice. As would a reply to my PM to him.
Old 02-19-2021, 07:20 PM   #16
Crown_Guy's Avatar
Rated Cap: 91
Yeah, that's why I'm pretty sure it's an HT740 to handle the 1000/ft/lb torque of the Big Cam II. That makes it a baby carriage to drive and it handles like a Really Big Car. Just right for those too intimidated to learn to shift and double clutch. But that's, as we all know, is all the fun, at least for those of us that can do it....
Old 02-19-2021, 07:22 PM   #17
Engine: TE 444
Rated Cap: 12
would be nice if I was not currently paying for my 98 MCI 102D3, which I am heading to Florida with in 2 days to Skoole swarm
Old 02-19-2021, 07:56 PM   #18
I'm going to go out on a limb here...and posit that @sfluke isn't really serious about selling. I looked at his prior post history and see a trend of posting once then not following up. Even though I already own too many buses, I was seriously interested in adding this to our "fleet"...even though I might get in trouble at home. But if a seller can't be bothered to read the rules (which state you must post a price) or respond to the considerable interest shown here or reply to direct messages...then I have to assume they aren't really serious and I'm going to take a pass.
Good luck with your sale @sfluke. She's a pretty bus.
Old 02-19-2021, 07:57 PM   #19
DeMac's Avatar
Coachwork: IC Corp
Chassis: RE-300, 42ft
Engine: 466ci
Rated Cap: 90
Kubla,
Are you saying that you are having to make payments for a retired bus? For real? A lein holder?
DeMac
Frederick Douglass:
"If there is no struggle, there is no progress."
DeMac is online now   Reply With Quote
Old 02-19-2021, 09:16 PM   #20
Engine: TE 444
Rated Cap: 12
second mortgage on the house, I have the title to the bus, no lean on it, but I did not have $11,000 in cash when I bought it
