yeah they are 12 VDC to 2600 watts of 120 VAC.. you need 12 volts DC input to it.. if you want to run the thing at anything close to 2600 watts you'll need some pretty fat wire on the DC side (shorter the distance between it and the batteries the better.
this particular brand was designed to run continuous at iots max capacity no issues.. some of the cheaper units will run at close to max capacity for awhile but often over-temp and shutdown unless the environment they are in is perfect.. ambulances, firetrucks.. service trucks, coach busses, etc would use these
