Originally Posted by drtbreau
For a newbie...when you see “doesn’t start, needs battery, local travel only” should that worry you if you can’t just verify it needs a new battery? (Coming from someone with no mechanical knowledge)
Unless they're practically giving it away, run away. There are too many running, roadworthy options under $4,000 to fuss with a bus that doesn't start and is good for "local travel only".
