Easiest way is with a friend, with one of you underneath the bus and the other inside. Person below clamps a vice grips on the nut; person inside loosens the bolt head with an ordinary wrench and a hammer, then uses a ratchet wrench to remove the bolt completely. If you have no friends, buy a bunch of cheap vice grips and clamp them on yourself - the more you have, the fewer trips up and down you'll have to make.
Even if the bolts are a little rusted this will usually work, and in a FL bus they really shouldn't be that bad. You might have a few ornery bolts that need to be cut out with an angle grinder, but your bus lot will probably run you an extension cord if it helps to be rid of you.
Exactly how we removed 28 seats, Musigenisis. Ratchet & vice grips, when I was alone. Wrench & battery ratchet, with a helper. We stripped the cushions before unbolting the frames to make them lighter & recyclable. Persistance.
If fact, we removed every bit of flooring, seats and ceiling using only an impact driver & hand tools. 1,056 screws in the ceiling, 124 seat bolts, 376 plywood screws. All in jars to reuse.
Stripping the seat bottoms ('removed seating') may be enough for the insurance company. Most can be done using no tool, just hands.
