06-10-2018, 08:32 AM
#21
https://youtu.be/4p2WMFgTcSw
This is the photographer and their skoolie.
I'd like to do something similar with logos on my bus
Namaste
Galaxie
06-10-2018, 07:43 PM
#22
Engine: 345 international V-8
1.2 Drivers Who Must Obtain a CDL
A CDL must be obtained by the driver of any of the following vehicles:
- Any combination of vehicles with a gross combined weight rating (GCWR) of 26,001 or more pounds, providing the gross vehicle weight rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
- Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing another not in excess of 10,000 pounds.
- Any vehicle, regardless of size, designed to transport 16 or more persons, including the driver.
- Any vehicle required by federal regulations to be placarded while transporting hazardous materials.
06-10-2018, 07:46 PM
#23
So I have not found that a business use vehicle needs a CDL. Unless it meets the above criteria.
06-10-2018, 07:59 PM
#24
Do you do any Reiki? or other healing modality? I do have an old travel trailer similer to an Airstream set up for this. So far have only used it here at home, but it is road ready , and have thought about taking it to expos and such. Will carry a massage table in our bus, however that is more for personal use, family and friends. I wish you luck with the business.
#25
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Ask your state's DMV/MVD or whatever name they may use. This forum is NOT the definitive answer. And scale your vehicle after you've stripped the seats.
06-10-2018, 09:04 PM
#26
Part 383 of the Code of Federal Regulations is the federal law concerning CDL requirements. It is a long read, but may well be worth it.
Just a few notes from it: the definition of a commercial motor vehicle is,
" Commercial motor vehicle (CMV) means a motor vehicle or combination of vehicles used in commerce to transport passengers or property."
So being "used to transport" does not convey used for business as in the example already given of ice cream truck, food service truck that food is served from. A food truck delivering food to the grocery store is transporting, not feeding people. See the difference? So I see the massage business as not material to CDL.
It also clearly states a school bus driver must have a cdl, even if just to test drive as a mechanic would, or transport it anywhere even without passengers. It is the ability to carry more then 15 passengers plus driver that puts it in the category of needing a CDL.
Recreational vehicles are exempt, so it would appear only after converting are we really in compliance. Although removing the seats so it could not carry more than 15 plus driver might be ok.
Ok. I am not a lawyer so have a look and see.
06-10-2018, 09:17 PM
#27
Yes, the seating capacity makes it a commercial vehicle, that's why the first thing we do is remove the seats, no longer meeting the requirements of a commercial vehicle. That's the easy part for driving it. As far as insuring it is where you have the most scrutiny on whether it meets the requirements of an RV or not. It's the insurance company in the long run that will care most if you are CDL or not, not the state.
What does it say you can drive with your standard license?
06-11-2018, 06:23 AM
#28
it does not say what you can drive with a standard license. That would be by each state I believe. This is Federal law I looked up for CDL.
06-11-2018, 07:31 AM
#29
I have not yet reached the part of my schooling for this but I am going to be learning the basics of this. Currently studying Energy Palpation which I believe is similar. Just finished my basics of reflexology and beginning polarity therapy.
Thank you so much for the help and especially for the direction of where to start looking. I'll certainly be looking up and reading into some of that document you mentioned.
06-11-2018, 07:37 AM
#30
Absolutely I will be as I move closer to buying my bus I will be getting the absolute bottom lines on all these things. Though it's been very helpful to get input from people here fellow New York state residents or not.
I honestly might just take the time after I've purchased my bus to pull the seats up and pile them in the back so that I'm below the standard of passengers before I drive it home. May just be the least hassle.
06-11-2018, 10:15 AM
#31
It should have a classification on what you can drive printed on the back of your license saying what type vehicles you can drive. What does yours say?
06-11-2018, 10:53 AM
#32
Stellar advice.
Drive without proper license
Drive without proper registration
Drive without insurance.
Sound like a great bit of advice.
If you should be so unfortunate as to "hit something " it will be a life changing experience.
Myself, I am not quite that adventurous.
This topic has been discussed to death. Insurance generally covers new purchases for 30 days. I called .... mine did. Everything else is a non-issue. Name one single forum member that has been penalized for any of the points you raised WHILE ON THE INITAL DRIVE HOME. If you can't cite a single example let's move on and stop peacocking.
06-13-2018, 03:16 PM
#33
Chassis: Front Engine
Driving without insurance is a big problem if you get pulled over or something happens... I'm in New York, here's what I did:
Bought bus in Indiana, insured it through a ny progressive commercial broker as a bus... drove in car to ny and registered it... when I did so I told them it was white and had less than 15 seats (no photos necessary) and I changed the gvwr to 26,000 so I didn't have to worry about cdl.
When I got home I ditched the $$$$ insurance and began the conversion... at this point I'll likely just do the Vermont RV plates thing and up the gvwr again if I think it needs it.
Drove back to Indiana and put ny plates on the bus and drove it home.
06-13-2018, 05:25 PM
#34
Driving Questions: CDL
Call your state highway patrol.
According to my state highway patrol in NC; I do not need a CDL as my 35' long RV is not used as a commercial vehicle to carry passengers.
My RV is a converted school bus.
I do have seatbelts in the chair and couch.
06-13-2018, 06:52 PM
#35
Chassis: CSFE
Engine: 5.9 Cummins ISB
Rated Cap: 25
Bus conversion Maine
When I purchased my bus I had to get commercial insurance to drive it home. I had a Class A license. I removed enough seats and took them home in a different vehicle so I could drive it. I purchased a transport plate for $13 and the the town clerk gave me a free 5 day pass for an uninspected vehicle. The plate was good for 10 days.
The state calls my bus an RV because we can sleep, cook and go to the bathroom. The insurance companies say no way. Because I converted it. They say ONLY a certified RV conversion will be acceptable. Sooo, I buy commercial for non-commercial insurance for private use and tell them it is just a bus. Dumb huh?!
Eric A. Hinkley
