Ugh, the old lady could be a real problem. You should be able to keep the bus in Philly with VT plates indefinitely (and even keep your insurance with Allstate - I've had VT plates for a year and a half now). You don't need the PA state inspection (that's only needed for a PA registration) and while you do technically need a VT inspection, that would only be a legal issue if you actually drove in Vermont (Vermont will renew your registration even if you never have the inspection done).
However, I think there are laws in PA regarding how long you have before you are required to transfer a vehicle registered in another state to PA registration, so after 30 or 60 days or something like that you'd technically be in violation. It would never come up as an issue unless (unfortunately) somebody is trying to make trouble for you. Although it may not be a problem - I had a neighbor call Code Enforcement on me after I had my bus at my house for a month, and the CE guy was pretty disappointed when I showed him my valid VT motorhome registration, because it meant he couldn't give me the boot (in my town, you can store a motorhome on your own property if you like). He did not bring up the inspection issue.
VT registration might take a month or two these days (they're apparently a bit backlogged at the moment). To avoid a sudden court order giving you a day or three days or whatever, it might be good to line up a parking spot for your bus at an RV storage place or something like that. Something for $100 to $200 a month should be doable, although they may be a bit sparse where you are (Mt. Airy if I remember correctly?).
Yeah, we're Mount Airy and you're right places off the road are in short supply but I might have a few leads should we need to do that. For now we have it on our drive but that has to be a temporary arrangement as we rent and it's a shared drive.
Vermont registration seems to be the most straightforward option - even contemplating a road trip up there to get it done plus not ventured that way before.
Other option is just to go the legit 'PA Way' proving its an RV seems to be straightforward enough according to the documentation:
If the applicant is requesting a change in the vehicle type to a motor home, additional photographs of at least four of the following components must be included with the application. These photographs must also be signed and dated by the enhanced vehicle safety inspector. If the vehicle is not equipped with at least four
of the following components, the application will be rejected when submitted to PennDOT for processing.
Cooking appliance
Self-contained toilet
Portable water supply
Separate 110/125 or LP gas supply
Refrigerator
Heating/Air conditioning Faucet and sink
We already have heating and AC installed and I was wondering whether I could just fix in some of the other easier ones above just to tick the boxes.
Guessing the potential pitfalls would be the enhanced mechanical inspection which I have yet to find a detailed description of.
Was thinking I would contact someone at the DMV to find out exactly what's involved - ideally chat to an inspection mechanic. The bus is in good shape so think I'm leaning towards the PA title option as then I can officially give that old lady and her two horrendous mouse dogs zero grounds for her to hassle us.
