10-03-2017, 01:28 PM
#241
directionals
BrewerBob - you were right - once I found the wire for the directionals - I was able to just piggyback the top lights - now they work perfectly!!!
Now people should be able to see me turning.
I am hoping this is not illegal - but I have seen trucks with high mounted directionals.
- Roger (Dog.Rescuer)
10-03-2017, 01:33 PM
#242
I know in ohio its legal high brake and turn signal are legal..but not legal to use high white facing lights front or back
10-03-2017, 01:35 PM
#243
I only plan to use those when parked - they do help light up the surrounding area.
I like the directionals, though! It will be hard to miss that I am turning!
10-03-2017, 01:37 PM
#244
Rated Cap: 65 pax
Originally Posted by tobeamiss
This is great! Thanks everybody for posting pics I'm so glad you all had a good time. I wish I could have made this one but I'll definitely be there for the next!
Now THAT'S a real bonfire!!It's only done right if you have to look up at it ;)
How's your toe CB? hehehe, not funny but funny lol. I'm gonna take a wild guess that you weren't wearing shoes ;) On a lighter note, so glad you now have a co-pilot chair Sandi. It'll surely make the trip more fun.
It was a great weekend, except for me crushing poor ECCB's toe with the seat
A wonderful skoolie community we have!!!
Sandi
10-03-2017, 02:06 PM
#245
Attachment 16248
Sweeeet!!
Per the MD state inspector (MD is a nanny state) you're alloweed as many clearance markers, brake lights, and turn signals as you like.
What Chris said. But in addtion to what he said, you're allowed "fog" lights and "spot" lights up high AS LONG AS THEY ARE COVERED. If you get a dick cop, he could give you a ticket for them being uncovered. There is nothing saying how they have to be covered and at least in the state of VA, a sock counts!! With covers mentioned, you might want to try to find some plastic cover that you can slip on and off without them flying off in the wind while driving. Or just roll the dice. Chances are the cop is going to get you for something if he's in that foul a mood. Those things can not be bright at all with the lenses you have. Clear lenses and headlamps would be totally different.
10-03-2017, 04:09 PM
#246
I was thinking someone did that.. installed headlamps.. and for some reason iwas thinking a round headlamp was pretty close to fitting in the opening.. whether the wire is big enough? no idea..
10-03-2017, 04:17 PM
#247
While its true I don't wear shoes much, I definitely don't wear em in someones HOME!
The feet of school bus chairs are not kind to pinky toes.
You are absolutely correct 😉 and those chairs are heavy! Hope you're doing ok 😊 [emoji106]
Sent from my SM-T350 using Tapatalk
10-03-2017, 04:25 PM
#248
I'm fine. It'll be ok. I broke a bigger toe way worse once, and they heal up pretty quickly.
10-04-2017, 06:45 AM
#249
I think someone mentioned it but don't know if they did. As for the wire, I can assure you neither the wire nor the fuse can handle it. I had the old bulbs in as parking/turn and it melted the 25 amp fuse. The circuit is rated at 15 amp.
10-04-2017, 09:31 AM
#250
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
LED could do it.
10-04-2017, 09:49 AM
#251
Originally Posted by Rusty
LED could do it.
Yes. I switched them all to the 1156 incandescent bulbs and the 15 amp fuse holds. The original bulbs (7" circles) were too much.
10-04-2017, 11:11 AM
#252
I put led bulbs in all the lights - so there is much less power drawn - seems to be working fine!
10-04-2017, 12:04 PM
#253
I know; you'll be fine. I was just putting that out there for anyone else. The circuit can't handle the original bulbs but then it was designed so that only one set at a time was lit and they were blinking at that. Brakes and turn signals are on the same fuse. You're on the brakes for a turn , that's the 4 rear lit steady. And then in my case, both rights or both lefts were blinking in unison. Current draw is MUCH higher than expected. The regular old school 1156 bulbs aren't exactly a light load in comparison to the LEDs but it maths to 15 amps.
10-05-2017, 09:11 PM
#254
Chassis: Ford B600
Rated Cap: 20 person
I heard that if you used LED lights you had to make a modification so the turn signal would work. Is that not the case?
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
10-05-2017, 09:17 PM
#255
I've not heard that - but I didn't make any modifications, except swapping all the little bulbs with LED bulbs. Everything seems to work well - much brighter and a crisper light.
10-05-2017, 09:24 PM
#256
Chassis: Ford B600
Thats good to know, i shouldn't listen to the autozone guy....
The Bowser Journal
#257
Chassis: Saf-T-Liner MVP ER
Generally this applies only to swapping out incandescent turn signals for LED, when a mechanical flasher relay is fitted. The LEDs don't put sufficient load on the flasher relay to trigger the on/off cycle. In fact what you are likely to get is a blown bulb indicator.
There are two ways to fix it. Either fit ballast resistors to the led circuit or swap out the flasher relay for an electronic one.
You might still need ballast resistors if the electronic flasher relay you fit (or is fitted), is load-sensing. Those are the relays that flash at double rate if a bulb is blown.
10-06-2017, 07:42 AM
#258
Good to know but 1) are these buses that smart? 2) Would they bother as they are supposed to be inspected daily before the driver starts the route.
10-06-2017, 08:04 AM
#259
most of our busses arent that smart.. but the way some of these flashers worked was essentially a self-resettig circuit breaker.. if you didnt pull enough current then it would not flash.. others were "reverse" sensing where the more current you pulled the slower it flashed.. many vehicles used these... alas why you would get the "fast blink" when a bulb was out..
if you go LED's you may very well get he super fast blink.. which to me is not an issue - fast flash = high visibility = Good
10-06-2017, 08:19 AM
#260
Dad's Econoline Van would vary speed with the brakes. May have had a bulb out as well but stuck on the side of the road with a flat, I was mashing the brake to make the blinkers flash faster as cars drove by. It was a '76~'78 maybe? Old enough that a late '90s bus should be as smart.
