10-06-2017, 09:08 AM
#262
50W at 12Vdc ... 4 amps. Yeah I guess that's about right but holy hell that's big when used to dealing with electronics.
10-06-2017, 09:40 AM
#263
no TRIAC wave chopping there.. 48 watt resistors LOL.. not like the typical 1/4 or 1/8 watt stuff we use in electronics circuits
10-06-2017, 09:47 AM
#264
Wave chopping??? Resistors don't do that anyway and this is DC so... . Yeah the 1/4 ~ 1 W were BIG. My '72 Duster had a wire wound 50W ballast resistor on it. As far as I know, that was as "electronic" as that car was. Carb, no ABS, ... well there was the voltage regulator with something for diodes in it. Separate from the alternator in those days.
10-06-2017, 09:56 AM
#265
thats why I said *NO* wave chopping here because these are resistors... and its DC...
10-06-2017, 10:02 AM
#266
Wasn't sure why TRIAC was even mentioned; are they cheaper/easier to find? Ballast resistor should be the cheaper/easier route but I haven't tried buying electronic parts in forever.
10-06-2017, 10:12 AM
#267
TRIAC is used in AC circuits and chops the wave.. in AC circuits they dont absorb the energy like a ballast resistor does in a DC circuit.. it was an off-the-cuff comment.. they are quite small.. the 600-1000 watt dimmers with the paddles in most newer homes are TRIAC based and dont require huge space and only small heat sinks..
10-06-2017, 10:45 AM
#268
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Yeah, overkill, but $6/ pair. I bet them LED's need the heatsink for dissipation.
I like this gizmo. Resistance is futile.
10-06-2017, 11:09 AM
#269
Chassis: Saf-T-Liner MVP ER
Generally they only need to be rated the same resistance as the bulb they are replacing .. so around 20W.
superbrightleds.com has decent examples. Too high a load could put a strain on the flasher unit.
