Motor AC is for when the motor is running because the compressor for the AC is attached to the motor. Probably what Ross's link was about.
Yes, you can run a separate AC off batteries/solar. You just have to do the math, set up the right amount of panels, batteries, etc., and you're cool.
The other option is to use a nice quiet inverter generator to run the AC and charge your batteries. In general, generators can be run during the late morning to early evening, when it's the hottest, so that shouldn't be an issue.
By using the generator to run the AC, and charge the batteries, you'll have full batteries during the non-generator time to continue to keep you cool.
Options are good.
Steve
