Old 06-15-2021, 07:32 PM   #1
Chassis: Ford e350
Engine: 7.3 powerstroke
'98 Ford E350 Econoline - Turning the rear AC to completely solar powered
I am starting my conversion on a 26 ft shuttle bus. I plan on doing more camping than driving, so I want my rear AC (See attached pics for reference) to run from solar or on grid plug-in.
Any recommendations on the best way to do this?
Jake&Hendrix is offline   Reply With Quote
Old 06-15-2021, 09:29 PM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
https://www.skoolie.net/forums/f10/p...a-c-36391.html
This similar thread from earlier today might be of interest.
Old 06-19-2021, 09:07 PM   #3
I would personally leave that for driving/motor on situations and just get a portable a/c or window unit thats seperate.
I would1l 100% just build my own LIPO batteries the alibaba way when i get there. (Last). With a small unit under 10ah i figured you could get about 18 hrs off 240 ah LIPO battery with no input. 2 of those batteries would be even better and 400w of solar panels would be my ideal minimal setup.
Fox Slider is offline   Reply With Quote
Old 06-19-2021, 10:09 PM   #4
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
Motor AC is for when the motor is running because the compressor for the AC is attached to the motor. Probably what Ross's link was about.
Yes, you can run a separate AC off batteries/solar. You just have to do the math, set up the right amount of panels, batteries, etc., and you're cool.
The other option is to use a nice quiet inverter generator to run the AC and charge your batteries. In general, generators can be run during the late morning to early evening, when it's the hottest, so that shouldn't be an issue.
By using the generator to run the AC, and charge the batteries, you'll have full batteries during the non-generator time to continue to keep you cool.
Options are good.
Steve
Old 06-27-2021, 11:13 AM   #5
Chassis: Ford e350
Options are good.
It sounds like there are a lot of options, and keeping the current ac / adding a small solar powered ac would be the ideal route. Thanks for the input!
