Old 06-19-2021, 02:06 PM   #1
Advice on engine
Hi
I’m looking at bidding on a 1993 ford e350 shuttle bus. In the posting it says it has a 7.5l engine. I’ve tried to research it but not much comes up. Is the 7.5l a good engine? Or is it something to stay away from?
Thanks
tbuell is offline   Reply With Quote
Old 06-19-2021, 05:21 PM   #2
That is the 460 big block. they were pretty stout motors and made 245 hp and 400 lb-ft of torque.
Azamof is offline   Reply With Quote
Old 06-19-2021, 05:23 PM   #3
The 7.5L ford is a '460' big block ford, and they are very good reliable engines.
The downside is they are very thirsty, 8 mpg is typical. If you drive a lot of miles, it can add up to more expensive. If parked a lot, might not matter much.
ford e350, short bus, shuttle bus
