RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-19-2020, 07:30 AM   #1
After Skool Special
My project is a 1986 Thomas 1700s shortie.ive got the seats ripped out and I’m currently tackling the floor removal...any suggestions on wheel chair ramp removal, it functions but outside of a gantry crane not sure how I’m getter her down and out
File Type: jpg 07AC89CA-0D49-41D6-813D-9E05A9572B5E.jpg (204.9 KB, 13 views)
File Type: jpg 8F3CFC12-53D8-4D97-A1C4-84BB2F3D1443.jpg (264.5 KB, 13 views)
File Type: jpg ED3FBF53-B77A-4EEB-8387-BEB7659338E2.jpg (287.6 KB, 15 views)
Aegarrison is offline   Reply With Quote
Old 03-19-2020, 07:33 AM   #2
I've removed a few of em.
Lower it to the ground, disconnect the power cable from the battery. Take the pins out of the arms on the ramp and cut the lines. pull it off in pieces/sections and its much easier. I can get one out and to the roadside in about an hour now.
Wear A Mask- Stop the Spread!
Old 03-19-2020, 08:30 AM   #3
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Love the name.
Old 03-19-2020, 01:43 PM   #4
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
You may want to leave it in during the build process, if you are going to use the bus for retrieving stuff. It will be make loading/unloading a lot easier.
Dave
Old 03-20-2020, 02:45 AM   #5
Our bus does not have one, but many times I would have loved to have the lift in place. Then again, we are using ours as a moving van.
Old 03-28-2020, 07:45 PM   #6
Chassis: Shorty 6 window handicap
Engine: Int 444e
Rated Cap: 21
I work at a warehouse so I was lucky enough to bring my bus there and pull it out with a forklift. Took all of 15 minutes with 2 people.
kcblkeeley is offline   Reply With Quote
Old 03-28-2020, 07:56 PM   #7
Update your profile with where you are -- somebody local to you might be able to help.
For example I'd remove a working one for somebody in exchange for it!
David
The Murder Bus
Old 03-28-2020, 08:11 PM   #8
If/when I get another you can have it.
Old 03-30-2020, 12:06 AM   #9
Engine: Caterpillar 3126
Rated Cap: 16
If my bid gets accepted, you’re welcome to come down to North Carolina and grab mine!!
KatTravels is offline   Reply With Quote
