RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-21-2021, 06:26 PM   #1
Year: 2009
Coachwork: Girardin
Engine: 6.6 turbo diesel
Rated Cap: ?
Air bag service light
So...i do drive the bus multiple times per week. No dummy lights on. Today the service air bag light came on. Does anyone know the significance or what my next step should be. I am thinking i need to get to mechanic, but cant do that for another 1 to 2 weeks. Is it safe to drive? Like not gonna blow up in my face or something? Thanks for any input✌
Buster Junior is offline   Reply With Quote
Old 01-23-2021, 09:46 AM   #2
Sander's Avatar
Year: 2008
Coachwork: Aerotech
Chassis: E-450
Engine: 6.8/415 Ford
I have a similar problem with the seat belt light in my Tacoma. Found that wiggling the wires located under driver seat fixed the problem till the next bump.
Check out this https://www.yourmechanic.com/article...r-bag-light-on #3 says "If your airbag light is on, it could also indicate a problem with your seat belts."
Sander is offline   Reply With Quote
Old 01-23-2021, 07:52 PM   #3
Year: 2009
Coachwork: Girardin
Rated Cap: ?
Hey there Sander. Thanks for the response. It was interesting because it was not on when i parked it one evening. It sat for two days. Then when i started it up, the light was on. So no bumps that i am aware of to trigger it. I will fiddle with the seat belt tomorrow. I should be able to get it to mechanic in a week or so to check it out. Wish me luck...it will be Buster's first check up since i picked him up a few mos ago🤞
Old 01-23-2021, 08:37 PM   #4
Get the codes read. Look for a fault with the clock spring.
Old 01-23-2021, 09:36 PM   #5
Year: 2009
Coachwork: Girardin
Rated Cap: ?
Ol trunt...i dont know what that means, but i will definitely mention to mechanic. Thank you!
Old 01-24-2021, 01:13 AM   #6
Sander's Avatar
Year: 2008
Coachwork: Aerotech
Chassis: E-450
Clock Spring.
Check your fuses.
I think Ol trunt is talking this: https://www.2carpros.com/articles/sy...g-clock-spring
You can have the codes read at most Auto parts stores. It would be better if you do that before taking it to the mechanic.
Old 01-24-2021, 01:51 AM   #7
Year: 2009
Coachwork: Girardin
Rated Cap: ?
Sander, i just read the link. Interesting, now i know why my mechanic asked me to check if the horn was still working. The horn and radio are fine by the way. When i told him this, he said he would run a scan for me. I already had an appointment set for his first checkup anyway. So i think i will just wait for that. I drove him all day today and all else seems fine, just annoying looking at the little dummy light. I will keep you posted. Thanks.
