Old 05-25-2023, 05:15 PM   #1
Engine: 7.3
An update and more questions...
1.Everyone was correct the cut wires to the heater were not the the cause of the bus not starting. I believe we may have left something on when it was driven home....
https://photos.app.goo.gl/YVNdHxguu2JS7RpB8
2. Removed the seat belt harness holder to prepare for leaky window removal, but the driver's seat belt holder seems like a doozy to get out. I was not intending to replace my ceiling. Also, I had planned to reuse the holder. Neither of those things seems possible now. Anyone had a holder like this? I've seen other posts about the bracket but none looked like this
PXL_20230525_210021294.PORTRAIT.jpg   PXL_20230525_210029508.PORTRAIT.jpg   PXL_20230525_210111232.PORTRAIT.jpg   PXL_20230525_210117299.PORTRAIT.jpg
so_cas is offline   Reply With Quote
Old 05-27-2023, 08:39 AM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
You should still be able to remove the window without removing the bracket, If you want to remove the header above the window you will need an allen wrench to get to the screw behind the bracket. Are you wanting to remove the ceiling panels? If so you will need to drill out the rivets.
Please update the starting thread if you were able to start the bus. Thanks.
BamaBus is offline   Reply With Quote
